Spreader bar fabrication question?
Instead of running the bar from A-Arm to A-Arm, would it not make more sense to run two of them? They would each go from the A-Arm cross shaft down to the chassis on the opposite side of the car.
My thinking behind it is this. When cornering hard, lateral force is applied on both the inner and outer suspension components.
In other words, if I'm turning hard left, the upper right shock tower area is being stressed out, and the upper left shock tower is being stressed in. I would think that there is more stress on the right side, and by rigidly connecting the two, it will impart even more stress on the left side. I would assume that this somewhat equalizes it out and by doing so, reduces the peak stress on the components. There is still going to be the same overall amount of stress imparted to the components that I'm trying to protect, just a lowering of peak stress.
So, by channeling that stress to the actual frame, would that not do a better job of reducing the flex?
Does anybody understand what I'm trying to say, or am I just talking gibb
erish?
Would love to see pictures if you go that route.
the normal bars are better than nothing, but the rod ends let things move around, which is bad for the car, but makes it easier to make since it's self aligning.
Personally, I think if you want to do it right you'd weld in a couple of bars
After giving it some more thought, I'm probably going to go with the tried and proven spreader bar configuration.
Heim joints will have to be used regardless, assuming I attach it to the A-Arm crossbar. Without the Heim joints, I would lose the ability to adjust caster/camber.
My problem is with what happens mechanically by running a cross brace at an angle from the crossbar down, and not being able to rigidly affix it.
Going straight across from the cross shafts means that the forces transferred into the spreader bar are almost completely lateral, basically negating the built in movement of the heim joints. By running them at an angle down, I'm afraid that the lateral flex from the towers will be translated into a sort of "jacking" movement.
Another option would be to eliminate the heim joints. The bars could be attached to the tower itself, just below the A Arm cross shafts. (there are already two holes there. The only problems I see with that are 1. moving the bars lower reduces the leverage on the tower. and 2. it would require a more severe angle to actually terminate onto the chassis itself unless I ran them to the chassis crossmember.
Thoughts?
Bernie
