plug wires...?
Old Dec 1, 2006 | 11:46 PM
bwellisley's Avatar
bwellisley
Default plug wires...?
upon trying to re-time the engine again prior to driving the car in for exhaust i found that my brand new autolight performance wires had gone bad! only a couple of hours of running time on them. they would not provide a reading with the timing light (light would not stay on) so, i took them back. those wires had 90 deg elbows on each end...is this necessarry? the wires i upgraded to are bosch premium that have 1 90 deg bend and 1 straight end. is this acceptable? would it look right to have the wires coming up out of the dist cap? should i take them back for another set with 2-90's? thanks!
Old Dec 1, 2006 | 11:59 PM
SIXFOOTER's Avatar
SIXFOOTER
I like the 90* on both ends because I like to tuck the wires up nice and close to the valve covers and route them clean and straight to the distributor. Its a personal preference thing, I always hated the way the stock shielding kits worked, it looks pretty when its all there but what a PITA to deal with
Old Dec 2, 2006 | 12:07 AM
bwellisley's Avatar
bwellisley
anyone have pics of what each would look like to compare?
thanks!
Old Dec 2, 2006 | 10:55 AM
Jc3vette's Avatar
Jc3vette
Have you checked out the MSD 8.5 super conductor plug wires? They have the 90 degree bends on both ends come in black or red. No radio interference when installed with out the stock shielding. Best plug wires I have bought.
Old Dec 2, 2006 | 12:51 PM
chris73cpe's Avatar
chris73cpe
can you pull the 90 degree caps off the plug wires? When I did mine there is no way I would've been able to fish the front 4 plug wires through the motor mounts with the boots still on.
edit..assuming you're still using the stock shielding that is
Old Dec 2, 2006 | 12:55 PM
sly vette's Avatar
sly vette
I agree. They work great and look even better!
Old Dec 2, 2006 | 01:27 PM
4-vettes's Avatar
4-vettes
Cruise-In VIII Veteran
I like the Packard replacement wires you can get from any one of the corvette supply houses, and yes you can get them through the moter mounts if you loosen them up and lift the engine slightly, the stock set-up looks good with all the nice chrome covers and they work great, And yes you will need to pull the starter to route the wires on the right side. If it's worth doing, it's worth doing Right.
Old Dec 3, 2006 | 08:48 PM
coupeguy2001's Avatar
coupeguy2001
2021 C4 of the Year - Modified Finalist
Default timing
you are taking the wire out of the distributor cap to time it aren't u? not off of the spark plug?
To plug wires...?
