Idle -> WOT = stall
I'm running 47k rods with 75 jets right now in my q-jet. If I ease in to it, it's ok. If I stomp on it, it stumbles then catches up. Whatcha think? Up the jets to 76 or 77 or something else needing to be addressed?
Timing is set to 34 degrees total centrifugal at 2500rpm.
Vortec heads, cam = 214/224, .442/.465, headers, sidepipes w/glasspacks (for those curious), Edelbrock Performer intake copy (professional products)
Ready set go!
BigBlockk
Later.....
Ready set go!
BigBlockk
Later.....
http://www.carburetion.com/quadrajet.asp
Not sure if this is what you need..I am not by any means a carb expert.
Secondaries vacuum or mechanical? It's a q-jet... mechanical lower butterflies but the upper butterflies don't open until they're needed. I should probably get some smaller secondary metering rods, too.
It is a very common speed trick to loosen the secondar windup spring to that secondaries will open very quickly. this is the single most common cause of a severe stumble or hesitation upon acceleration or transition into the secondaries.
Are you sure that your secondaries are not coming in too early?
And I dare not tinker with the secondaries yet. Plus the secondaries wouldn't open just from hitting WOT from a stop. They don't open until at least 2500rpm or so.
The primaries are TINY.
To the original question, also ensure your float level hasnt somehow changed.
Some more info for y'all. Prior to having the stock heads replaced with the vortecs it didn't have ANY problem. It ran flawlessly, with the exception of the chock pull-off being too rich. Ignition is where it should be now, the vacuum leak in the brake booster is fixed, and all of the vacuum lines seem to be fine. It's obviously not running rich because there's absolutely no stinky gas smell or black smoke ever.
Would it be worth it to try larger primary metering jets? I've a feeling my rod/jet combination is too lean for the intake/heads/cam/exhaust combination.
Did Lars vehicle test/tune your carb after rebuilding? If not, I would vehicle test/tune the secondary wind-up spring after you solve the primary problem.
Lars did test/tune my q-jet on his vette. I'm the only person that has taken the airhorn off and really tinkered much with it (the exception being the idle screws, choke pull off, and main idle screw) so I know the secondaries are just as he had them. I also know i need to go to a smaller secondary rod, that's kinda obvious.
Oh and I talked to a few carb shops and they're immediate diagnosis was the accelerator pump spring, also. So I'm thinking bigblockk is right, like he almost always is.
I'll call Larry at the Corvette shop on Monday, too, to see what he thinks. I might let him have a go at it if he can do it without making my wallet nearly disappear.
Wasn't the accelerator pump spring, but the pump DIAPHRAM!!
Little background, I replaced the pump a year and a half ago because of a similar problem when I first got the carb. Got a brand new edelbrock pump and installed it. Still had the hesitation problem and the dyno shop cured it somehow, not sure what they did though.
So what was wrong with the diaphram? It was ripped at the top where the plunger pushes down on it. I brought them my original pump I had in it and it turned out to be an original GM one. >_< The GM pumps are skinnier in diameter. We got lucky and they found a diaphram that fit, in their parts assortment.
Also fixed the choke, apparently the rod was upside down. Not sure how that happened but it did. Also found out some of my well plugs are starting to leak. Easy JB weld fix, I'll wait till lars comes out to fix those. Power steering valve needs to probably be repaired or replaced. Doesn't bother me but it scares the crap out of anyone else.
Apparently my dampener is spun, because he said he couldn't get an accurate timing mark. Seems odd though because I could get a timing mark with my light.
He did it by ear/seat of pants and it isn't pinging so it should be ok. I'll try advancing it more, if there's no pinging tomorrow.So results of the overcharge on labor for the little work they did? Runs pretty good. Idle is a little lower, but that's a simple twist of a screw. I prefer it to be between 600 and 700 in gear, so the alternator spins fast enough to hold a good charge. It doesn't stall or hesitate any more. Actually got the wheels to spin a bit from a stop. I just e-mailed lars a minute ago asking for recommendations on jets/rods since my head/intake change. I think I need to go up to 76 jets and see how those do for me. Until next time!
that it is most likely the accelerator pump. The other problem could be that the secondaries are coming in too early. Are your secondaries vacuum or mechanical?
