Torque converter recommendations please
Old Dec 3, 2006 | 02:08 PM
MonzaRedConvert's Avatar
MonzaRedConvert
Default Torque converter recommendations please
I just got my TH400 rebuilt to go with my new motor and I was informed that my converter is toast. Anyway, I'm looking for some advice about which one to go with. My combination is:
'69 vert, 350 +.030, 10.5:1, Edelbrock RPM heads, Comp 282S cam, factory hi-rise intake, Holley 750 VS, headers, 3.36 gear. The car will be mostly street driven though not every day and will see the occasional trip to the strip.
I've looked at a few manufacturers and I think I'm going with JW. I've raced with their stuff before and had good luck. They have two 11" converters that I'm considering. One is listed as 2400-2700 stall and the other is 2800-3000. I can't decide which one would be better for this car. If anyone has any advice or can recommend a different converter I'd be grateful.
Doug
Old Dec 3, 2006 | 04:53 PM
itsonlyairandfuel's Avatar
itsonlyairandfuel
You want your stall speed to be below your cruise rpm, to avoid excessive heat from slippage. If its more of a drag car 3000 or more depending on your cam. Mine is primarily a track car with about a 3000 stall (243 in-251ex @.050) and the next time I change it will be 4000 or more. Ron B.
Old Dec 3, 2006 | 06:11 PM
ajrothm's Avatar
ajrothm
At least the 3000. Usually a 3k is in a 10" body. Look at Art Carr, Vigilante, Yank, Continental and even some Hughes.
Stay away from TCI, B&M and local speed shop specials
Old Dec 3, 2006 | 07:21 PM
Ironcross's Avatar
Ironcross
Not knowing the ingredience of the engine you could not go wrong with the T400 OEM converter used in the 1969 L71`s and L89`s.
Old Dec 3, 2006 | 08:04 PM
69 N.O.X. RATT's Avatar
69 N.O.X. RATT
From: Pettis Performance 565 with two stages of Nitrous Supply nitrous 1.082, 4.61 at 155, 7.17 at 192
Look up Edge converters on the internet. I just put one in my race car. There are very reasonably priced and really stand behind their product.
To Torque converter recommendations please
