Looking around under my car and noticed what looks like a weight on the flange behind the yoke on my diff.I have a vibration problem around 75 when I'm getting on it,and it looks a little bent on one side probaly nothing but I have to ask
A lot of the pinion yokes indeed have a small weight on the dust shield, it's spot welded on (there's 2 little dimples on it), supposed to be that way.
i'd check the pinion bushing and trans bushing first
How would one check the pinion bushing? I've had my main shaft balanced also the factory manual says to check the companion flange for being loose. BTW gtr1999 you have done some very informative posts on rear ends I'm sure have helped alot of people
