heavy duty u-joints
Old Dec 4, 2006 | 01:43 PM
77vetteuk's Avatar
77vetteuk
Default heavy duty u-joints
Hi, Can anyone help me find a shop that can supply good qualty heavy duty( axle shafts) u-joints for a 77 auto and part no if poss.
One of the last ones i put in has cracked.
Old Dec 4, 2006 | 02:04 PM
jbierschwale's Avatar
jbierschwale
Ssstrange Engineering....
http://store.summitracing.com/partde...5&autoview=sku
Old Dec 4, 2006 | 02:44 PM
MEGALADON's Avatar
MEGALADON
From: WAY DEEP INSIDE AMERICO,YES YOU LIVE HERE TO!! TX
I use (BRUTE FORCE) from auto zone or O'riley auto parts.
I treat my car like I stole it, and never had a problem with
braking u-joints Just my .02 on u-joints. You don't
need high dollar joints for street use, unless you got the power
to break them.
Plus my car is not stock in any way, and they still have not popped
on me (knock on wood) LOL
Old Dec 4, 2006 | 04:38 PM
GTR1999's Avatar
GTR1999
I use SPICER's and posted last week about them. This may help you. http://forums.corvetteforum.com/show....php?t=1548292
I broke a zerk joint in 1/2 without any abuse at all.
Old Dec 4, 2006 | 08:21 PM
shafrs3's Avatar
shafrs3
P/N for Brute Force half shafts - 2-0053BF.
I don't have the driveshaft p/n's.
Old Dec 4, 2006 | 08:38 PM
b71vette's Avatar
b71vette
I totally agree with using spicer lifes, spend the extra bucks and be done with. Check your local driveshaft shops in the Yellow Pages, my local shop charged about $10 less per u-joint than what I found on e-bay and only charge $7.50 per joint to install, when you take the shaft into them, I also had mine re-balanced just to be sure.
Old Dec 4, 2006 | 09:08 PM
ratflinger's Avatar
ratflinger
NCM Grand Opening Veteran
St. Jude Donor '11, '17
Van Steel carries Spicer u-joints as well as a generic brand either with or without grease zerks.
Old Dec 4, 2006 | 10:35 PM
427Hotrod's Avatar
427Hotrod
2020 C2 of the Year - Modified Winner
2020 Corvette of the Year (performance mods)
C2 of Year Winner (performance mods) 2019
2017 C2 of Year Finalist
I use Spicer solid ones for peace of mind.
I get them at local driveshaft shop. Best stuff going.
JIM
Old Dec 5, 2006 | 04:12 PM
Van Steel's Avatar
Van Steel
Premium Supporting Vendor
I carry both Spicer & Neapco joints. Both are cryo'd as well. I personally don't know what all the hype about Spicer is about. I mean they are good joints but I believe the Neapco's are just as good if not better. Spicer has the plastic seals, that will more than likely break when you install them, which in turn causes them to fail prematurely. I like the rubber seals better. Less hassel and the same quality.
1/2 shaft joints are a 799 or a 1350 series u-joint
driveshaft joints - 1971-1979 are 790 or a 1330 series joint
Old Dec 5, 2006 | 09:02 PM
shafrs3's Avatar
shafrs3
Originally Posted by Van Steel
... I personally don't know what all the hype about Spicer is about....
I don't either.
Old Dec 5, 2006 | 09:29 PM
wfo76's Avatar
wfo76
The NEAPCO is the Brute Force right?
Old Dec 5, 2006 | 09:43 PM
ratflinger's Avatar
ratflinger
Well gee whiz!! Guess what I had delivered today, yep spicer u-joints. Dan, you want em back?
To heavy duty u-joints
