Light Weight Fly Wheel?
Old Dec 4, 2006 | 02:41 PM
KJL's Avatar
KJL
Default Light Weight Fly Wheel?
I am installing a Tremec 5 speed in my car and am not sure if I should go with the billet steel 33 lb unit or the 15 lb light weight unit. Gene at Keisler has recommended the billet fly as best for around town driving.
Any advice?
Old Dec 4, 2006 | 02:56 PM
69427's Avatar
69427
From: I tend to be leery of any guy who doesn't own a chainsaw or a handgun.
Any advice?
My opinion: If this is strictly a street vehicle, and lots of city driving, I'll agree with Gene. A heavier flywheel is much easier to use when taking off from a stoplight.
OTOH, if you do much performance driving (road course stuff), a lighter flywheel is the way to go. (Plus, a quick revving engine just sounds nice. )
Old Dec 4, 2006 | 03:36 PM
rastadr's Avatar
rastadr
i agree that a heavier flywheel is a nice thing for stop and go but in my 70 lt-1 with 485hp the super light flywheel really let the motor spool up very quickly. once you have that, its hard to go back to heavy. you learn how to handle it quickly. a close analogy is having a 3000 stall converter. the motor likes it alot.
Old Dec 4, 2006 | 03:53 PM
panic's Avatar
panic
what would be the best type/brand lightweight flywheel? i have a 406ci..
Old Dec 4, 2006 | 04:15 PM
Ironcross's Avatar
Ironcross
GM has both necessary for internally balanced and externally balanced engines. 400 ci engines are external though. Approximately $200.00 for either one.
Old Dec 4, 2006 | 04:46 PM
vetteaddic's Avatar
vetteaddic
Do they have the lightweight flywheel for 11'' clutch?
Old Dec 4, 2006 | 05:07 PM
Gordonm's Avatar
Gordonm
I asked that question a little while ago. Here is the thread on the answers. I did purchase a 12.5 aluminum wheel and will have it in this winter. I am running a 30+ pounder right now.
http://forums.corvetteforum.com/show...minum+flywheel
Old Dec 4, 2006 | 05:08 PM
Gordonm's Avatar
Gordonm
Certainly do. I purchased a Fidenza 12.5 pound wheel 2 weeks ago.
Old Dec 4, 2006 | 06:41 PM
Ironcross's Avatar
Ironcross
Not GM. The size of their HD clutch is a 10.4 diaphram style for the L88 and ZL1 engines. 11 inch clutches are not factory for those engines.
Old Dec 4, 2006 | 06:51 PM
bbeck's Avatar
bbeck
who all is running a light flywheel?
Old Dec 4, 2006 | 07:09 PM
Gordonm's Avatar
Gordonm
Check my post from above. There is 3 pages of good info on light flywheels.
Old Dec 4, 2006 | 07:44 PM
84rzv500r's Avatar
84rzv500r
15lb nodular Iron from GM on my 502 !!
Old Dec 4, 2006 | 10:34 PM
I'm Batman's Avatar
I'm Batman
St. Jude Donor '07
400ci are only guaranteed to be externally balanced with a stock crank. I've got an internal-balance forged crank in my garage, wating for my 412 build.
Old Dec 4, 2006 | 11:44 PM
TimAT's Avatar
TimAT
I've got the light flywheel on a 454. It's got enough torque the weight is not a real factor. Plus it spins up like -- RIGHT NOW!
Old Dec 5, 2006 | 10:19 AM
69autoXr's Avatar
69autoXr
I have the GM nodular iron on my LT-1, and I can't say I've noticed any real difference in the launch quality from the heavy flywheel to the light one.
Old Dec 5, 2006 | 10:35 AM
bence13_33's Avatar
bence13_33
I run a 15lb aluminum one behind my 468 and the difference in how fast it revs is noticable. I don't think I'd go back to a heavy flywheel unless strength became an issue.
Old Dec 5, 2006 | 03:27 PM
bbeck's Avatar
bbeck
well, I've got another thing to add to my wishlist then....
To Light Weight Fly Wheel?
