Front End rebuild
greg
It is a PITA, cause you need to remove the radiator and associated parts. Used a local shop to clean the arms and press the bushings.
Cleaned and painted what I could reach, and then re-installed my the arms. It is do-able.
When I bought the front parts I also bought upper control arms but didn't install them at the time because I couldn't figure out how to remove the upper control arm bolts. Big mistake - the old ones have some dry urethane bushings and squeak badly. I am replacing them either this week or next. Here is a link to the solution http://www.vetteweb.com/tech/vet_030..._replacements/. When you get VB&P's new light weight control arms the bushings are already installed.
As far as installation goes, until I bought the Corvette I had not even changed my own oil since I was a kid - a long, long time ago. We took the old front end off on a Saturday afternoon and put it back together on a Sunday morning. Pretty easy! The hardest part was one ball joint didn't want to come apart. I spent a half an hour on that.
We replaced springs, shocks, all 4 ball joints, tie rods, tie rod ends, sway bar bushings, power steering cylinder and idler arm. Parts about $1,300 to $1,400.
By the way the 'we' is me and . . . my wife. She has never a serious wrench in her hand in her life.
She also discovered that she still likes a beer now and then.
We also replaced the lower control arms.
I did have friends helping me (thank you Tim and LA).
I also have pics of all that I have done so if you need a reference, let me know.
VB&P is where I got all my kits from. They are great. I had bad experiences with Vansteel although I did get one of my 3 rear end kits from them.
It is a great improvement. I recommend it to anyone. If you dont have a shop full of tools, most local shops will help you with pressing bushings in and out if you need it.
www.angelfire.com/al/swhite7/frontend.html
YBnormal...drive a vette
