Flex Fans
Old Dec 4, 2006 | 06:18 PM
sjmaster's Avatar
sjmaster
Default Flex Fans
Are flex fans (the type with thin stainless blades) worthwhile? I don't have a cooling problem, but was considering a new fan when I change the water pump. By the way, on the pumps.....are some equipped with sleeve bearings and some ball bearing?? If so, which is preferred.?
Thanks!!
Old Dec 4, 2006 | 06:38 PM
VCuomo's Avatar
VCuomo
I've used them on small block Corvettes ('72 and '73). IMO, they blow more air (way more air, in fact) than the stock clutch fan. I have an electric fan on my '72 now, but I still have a stainless flex fan on my '73 and haven't had a problem with it (its been on for over a year).
Old Dec 4, 2006 | 06:53 PM
sjmaster's Avatar
sjmaster
Thanks for the reply. Yes, they should move more air at idle....but according to literature, they lose pitch at high RPM, reducing airflow accordingly. I think the stock clutch reacts not only to RPM but temperature. I am mainly worried about them coming apart and damage to hood etc.
Old Dec 4, 2006 | 07:08 PM
Gordonm's Avatar
Gordonm
I had one on a car years ago and it sounded like an airplane above 3500 rpm. Just my experience with one. They may be better now.
Old Dec 4, 2006 | 07:13 PM
69camfrk's Avatar
69camfrk
From: GA "When I grow up, I'm gonna get a Trans Am and run from the cops". Direct quote from my 4yo son.
Nope, they still sound like you're getting ready to take flight!! But I have found that loud exhaust masks the sound!
Old Dec 4, 2006 | 08:12 PM
blue427's Avatar
blue427
Ive been using a flex fan on my 427 for a few years now,no problem.Noise,?,can't hear a thing over headers and side pipes.Ball bearings are better then sleeves
Old Dec 4, 2006 | 11:00 PM
longbros's Avatar
longbros
My 1969 GTO came from the factory with a flex fan. The car has 175,000 miles on it, same fan. Never had any problems with it.
Old Dec 4, 2006 | 11:04 PM
19vette80's Avatar
19vette80
I've had 0ne on my 80 for three years iv gotten alittle better gas mil and runs about 5 degrees cooler at idle.
Old Dec 4, 2006 | 11:05 PM
Fubba's Avatar
Fubba
I've heard MANY horror stories about blades flying off. Make sure you get a NICE one and not a cheap generic one. Most have an RPM rating you can go by nowadays.
Old Dec 4, 2006 | 11:12 PM
CheckerVette's Avatar
CheckerVette
I put on the flexlite version of flex fan in place of the stock thermofan. I love the sound of it mixed with my gear drive cam set up it sounds like a supercharger (not quite but hey it fits under the hood) Never blew one up and I had one on a Chevy II with 4.11 gears and 14 inch tires TH350 many many miles and lots of high RPM shifts. I think some of the guys that clain they blow up are the kinda guys that damaged them somehow and kept using them. The Flexlite I have is rated to 10,000 RPM I imagine the engineering team incorperated a safety factor in that figure as well!
They sound just awesome I went with a 17 inch on my 75 but I think if your motor mounts are good an 18 will fit stock shroud!
Old Dec 5, 2006 | 01:39 AM
Vesa's Avatar
Vesa
Thanks!!
Stay away from them - the cooling capability is less far smaller than non flex ones!!! Been there, done that - now non flex aluminium without fan clutch and no cooling problems...
Old Dec 5, 2006 | 03:57 AM
babylonvette's Avatar
babylonvette
Default flex fan
they work great ,got one on my 61, if it wasn't for the flex fan i wouldn't even know the car was running at highway speeds
To Flex Fans
