please help, '78 L-82
Old Sep 25, 2001 | 07:20 PM
c5vette98's Avatar
c5vette98
Default please help, '78 L-82
hey, can you guys click on this link and help me out with my problem.
http://www.geocities.com/c5vette126/stuff.html
I need to know a how the hoses hook up to these ***** in the picture and I need to know what those two bolts are called, what they look like, and if i can buy them and where.
Old Sep 25, 2001 | 07:36 PM
1976C3's Avatar
1976C3
Default Re: please help, '78 L-82 (c5vette98)
picture 1:
Is that green valve vaccum fitting go into the intake?
That looks like an egr item.
There should be an egr diaphram on the the choke side of the carb mounted on the intake with a vaccum hose nipple.
Attach the lower fitting from the green valve in picture 1 to that egr diaphram beside the carb.
Attach a vaccum hose from the top fitting of the green valve in picture 1 to the nipple on the carb in picture one you have circled.
That is the egr system. If you do not plan on using egr, plug those 4 nipples.
2 on the intake valve, 1 on the diaphram, 1 on the carb.
picture 2 is of the A.I.R pump, you need 2 bolts for it. I do not know the tech. names for the bolts but you can print the picture and take it to a gm dealer and tell them your year and that you need those 2 bolts for a air pump, that should get you squared aware at least.
[Modified by 1976C3, 11:40 PM 9/25/2001]
Old Sep 25, 2001 | 08:04 PM
78Vette-SA's Avatar
78Vette-SA
A pics worth 1000 words:
Also, you have mail coming. If you need more info, just let me know. I also have lots more pics on my web site.
Old Sep 26, 2001 | 01:12 PM
tunedport78's Avatar
tunedport78
Default Re: please help, '78 L-82 (78Vette-SA)
Thant Probably doesn't help does it?
To please help, '78 L-82
