Ride Height Too High
Old Dec 5, 2006 | 10:33 AM
JIMS1970VETTE's Avatar
JIMS1970VETTE
Default Ride Height Too High
Hi, after having suspension work done including a new steel stock rear spring, the rear ride height is to high, I believe that there is a longer bolt to drop the ride height, but I thought to see if anyone else has had this happen and what they did to lower their height.
Old Dec 5, 2006 | 11:09 AM
GruntyPants's Avatar
GruntyPants
What other kinds of suspension work? Have you driven the car much to get the suspension to settle in? I don't know how 'correct' the spring you got was compared to the one that was on it, some are more curved or designed for different weights, more than likely you'll just need the longer bolts for the rear so you can set the ride height like you want it.
Old Dec 5, 2006 | 11:13 AM
Garys 68's Avatar
Garys 68
I changed the old rubber bushing for poly and it raised the rear a little.
I used the longer bolt kit to drop it.
Old Dec 5, 2006 | 04:02 PM
Van Steel's Avatar
Van Steel
Premium Supporting Vendor
Fiberglass spring or steel spring? 8" Bolts should drop you down.
Old Dec 5, 2006 | 05:15 PM
FKING1's Avatar
FKING1
Is what I did.
Fred
To Ride Height Too High
