Welding the shock towers
I wanted to reweld the complete seam between the tower and the frame so first you must clean the entire area, I use a wire wheel and a grinder to get as much as possible out of the area, no paint allowed. I then make the first pass to heat the area and then hit it with shop air to blast the paint and grease out of the seam. I really find hitting it with shop air really helps, even puts out the small fires.
I weld parallel to the seam, weld all holes closed and you will find a big hole in the corners, up to ¾ inch hole. Anyway I weld parallel to the seal then stick across it vertically for about an inch overlapping the welds.
I would then again run beads parallel to the seam and fill everything in.
Later when it cools I grind the whole area for looks, prime, rockguard and then paint. I have them primed now and ready for rock guarding. The rock guarding gives a nice coverage, is a hard thicker finish that gives a nice appearance once painted.
I also run a big spreader bar from the cross shafts to prevent flexing
I also run a big spreader bar from the cross shafts to prevent flexing[/QUOTE]
Looking good Norval, but now you are going to have to drill some more holes to make up for all the weld material you added !!
Jeff
Here I go talking like a horseman. LOL
Jeff
If 540 blown cubic inches can't move a little extra weight I will just give up.
Everything is ground and primered. It looks smooth now and I am ready to rockguard this section of the frame.
The rockguard goes on really nice, gives a good surface and I paint gloss black over that once it has dried.
I believe in welding hot and fast.
start drilling damnit.....
must be another .00000001 et there......
It is a long winter and I have lots of time so I might as well do anything that I can think off.
Honestly Gene I would give up the car before I would give up my horse. I have more money invested in the horse then in my car even with it's $20,000 motor.
The horse is always glad to see me, even calls to me as soon as I show up at the barn. I have yet to see the car make any response to my appearance LOL
No give me a good horse any day over a chunk of cold steel.
I won't leave anything that rough on the car. It must blend, look original. I don't to bubba work.
A simple single pass is too easy LOL]
I will have to rock guard it and then take another picture.
it'll look good smoothed...I have to admit though, I blended the very same area
I would love to go dry sump but with a 4 inch blower belt it pretty much takes up all the room.
