LS1 conversion ?
Old Dec 5, 2006 | 03:19 PM
MYBAD79's Avatar
MYBAD79
St. Jude Donor '05
Default LS1 conversion ?
I'm still busy with the bodywork and paint but I just got a pretty good offer:
LS1 and 6speed tranny from a 2000SS with 60K miles, all accessories included (water pump, AC, PCM, injectors, intake, TB,clutch)
It's a local junkyard, I can probably get the pedals as well (auto conversion)
I thought about the TKO 5speed conversion but now I can get the T56 and the engine for less than what the tranny conversion would cost.....
will the T56 fit ? Do I have to shorten the driveshaft ? How much of a "bolt in" is this ?
Old Dec 5, 2006 | 05:03 PM
72LS1Vette's Avatar
72LS1Vette
Make sure you get the wiring harness too.
The LS1/T56 isn't a simple drop-in but IMO it is worth the effort involved. There are motor mount adapters available for ~$50.00 that will take care of positioning the engine. The T56 is ~3" longer than a 4-speed so the trans crossmember needs to be modified. The trans yolks are different also so try to get the one from the SS. The driveshaft does need to be shortened to work.
Guages are another issue. The T56 speedo is electric, tach is electric, oil pressure is electric.
The shifter hole in the tunned needs to be opened up a bit for the T56 but if you are converting from an auto you have to cut a hole anyway.
Not sure if the pedals will fit. You might be better off getting a C3 set or putting your own set together from parts. From what I can see in the AIM both standard and auto pedal setups use the same bracket.
The fuel system needs to be modified also. An electric pump must be used. There are a variety of ways to plumb the fuel system.
I think that sums up the major changes - there are also many details that need to be taken care of.
Like I said before, I think it's worth the effort.
Rick B.
Old Dec 5, 2006 | 08:04 PM
SuprJames's Avatar
SuprJames
A used pedal assembly is like $30 out of a C3. See no reason to go through the hassle of doing the Camaro pedals.
Have any questions or want any pics I can help you out as well seeing as I have no body on my frame yet.
Old Dec 5, 2006 | 08:11 PM
wnmech's Avatar
wnmech
I dont have an LS1 in my corvette just a well built 350 but I have a 2001 formula with a ram air 320 horse LS1 and It will run the britches off of my 77 corvette. If you make it happen you will be pleased with the performance.
Old Dec 5, 2006 | 08:17 PM
Little Mouse's Avatar
Little Mouse
Budman78 put an LS1, 6 speed out of a camaro into his 78 auto
vette, PM him he will probably give you the heads up on what all
it takes to do the job.
Old Dec 5, 2006 | 10:26 PM
MYBAD79's Avatar
MYBAD79
St. Jude Donor '05
Thanks everybody - I didn't think that I would even consider this swap at this time but the offer is too good to turn down.... It's a local business so I can at least see the engine before I buy and make sure it's complete, check fluids, look inside the valve cover, pull a spark plug or two and so on....
I have the LS1 in my '99 Z28, it performs pretty well with the auto tranny, can't imagine how much fun it's going to be with a 6speed manual.....
I don't think my sidepipe headers will fit the LS1
Old Dec 6, 2006 | 10:10 AM
72LS1Vette's Avatar
72LS1Vette
If you get a good enough deal on the package you could always sell it ofr a profit if you decided not to use it. People are putting LS1s into Miatas these days.
You can use your sidepipes on an LS1 with some modifications. PatsLS1Vette did it on his by using LS1 flanges and reworking the ends of the pipes to fit. Looks great and I'm sure it sounds awesome. I think SuperJames has sisepipes on his motor also. Check his pics for a good look at how everything drops into the frame.
Rick B.
Old Dec 6, 2006 | 10:23 AM
MYBAD79's Avatar
MYBAD79
St. Jude Donor '05
Rick B.
I found superjames photo of the LS1 with sidepipes - wow, that looks easier than I thought.
They're asking $4200 but I think I can get it for $4000. I think it's a great deal, considering it's local and I can see the stuff before I buy.
I'll have to make up my mind....
Old Dec 6, 2006 | 09:48 PM
69427's Avatar
69427
From: I tend to be leery of any guy who doesn't own a chainsaw or a handgun.
Sounds like an interesting transplant. Please keep us updated on this if you go forward with it.
Old Dec 7, 2006 | 02:45 PM
Pauld's Avatar
Pauld
Old Dec 7, 2006 | 02:57 PM
MEGALADON's Avatar
MEGALADON
From: WAY DEEP INSIDE AMERICO,YES YOU LIVE HERE TO!! TX
HOLY SMACK You can buy them down here all day long for $2800.00
without the computer Maybe $3000.00 with it.
To LS1 conversion ?
