Found a 427
Old Sep 25, 2001 | 09:13 PM
C3sharkattack's Avatar
C3sharkattack
Default Found a 427
Well guys I found a 427 from a 69 Stingray ( not tri-power ) that burns oil, the guy only wants $200 for it so I am very much considering it. My question is, if I can get it and a nice transmission would the 427 fit in a 75 stingray?
Old Sep 25, 2001 | 10:28 PM
bb69's Avatar
bb69
Default Re: Found a 427 (C3sharkattack)
I'd like to tell you no...and then ask where this engine could be found. :D Honestly, anything will fit with enough work. I'm sure someone can tell you what needs to be changed, but I would imagine you'd need new engine mounts and trans mount. Also, you may need a new radiator, fan shroud, and other various pieces. The only other thing I can think of now is the location of the the shifter in the console if it's a manual. Good luck and let me know if you pass on that engine. :cheers:
Old Sep 25, 2001 | 11:25 PM
Tahos's Avatar
Tahos
No it would be too much work to put it in a SB car.By the way where is this
$200 427 engine ? :D
Old Sep 25, 2001 | 11:30 PM
Dwaynes69BB's Avatar
Dwaynes69BB
From: I can explain it to you, but I can't comprehend it for ya.
Default Re: Found a 427 (Tahos)
whoooaaa, thats way too much money for a 427 that burns oil...give me the guys number and I'll call him personally to let him know. :D
Old Sep 26, 2001 | 01:24 AM
marky mark's Avatar
marky mark
Default Re: Found a 427 (Dwaynes69BB)
If it's a tall deck "truck" 427 you may have some difficulty with brackets and possibly hood clearance. Also, it is impossible to tell if it's actually a 427 (or 396,402 454,etc) without some more info. What #'s can you find on the rear of the block by the bellhousing (driver's side on top) and the front (passenger side) "pad" where the block attaches to the head. If you give us the #'s we can i.d. your block at least.
Good Luck! mark
:flag :chevy
Old Sep 26, 2001 | 01:32 AM
honaker's Avatar
honaker
I think the guy is ripp'in you off. Let me have is info so i can report him. :D
Old Sep 26, 2001 | 01:37 PM
Stefan69's Avatar
Stefan69
Yes, it's possible to put it in there.
Couple of changes are necessary, but if you search the archives, there are plenty of threads on the subject. Biggest problem is typically emssions. However, and this is serious: I'd take it if you don't want it (and the shipping isn't too bad). I always wanted a replacement for my rebuild #s matching engine, so I can let the original rest in the basement and build a powerhouse to drive around with!
Lemme know!
Stefan
Old Sep 26, 2001 | 01:43 PM
71coupe's Avatar
71coupe
Default Re: Found a 427 ()
marky mark - If it's a truck block, it should fit. I think they make aftermarket intakes that will fit without the adapters.
Old Sep 26, 2001 | 01:47 PM
norvalwilhelm's Avatar
norvalwilhelm
I installed a 454 in my 75 and it fit without any problems. The original motor mounts, transmission and ignition work fine. I even used the power steering and alternator and for a few years the stock 2 core rad. Headers fit effortlessly. I didn't have AC so no problem. The power brake booster can cause problems with tall valve covers.
Go for it.
Norval
Old Sep 26, 2001 | 07:17 PM
C3sharkattack
Default Re: Found a 427 (marky mark)
Good Luck! mark
:flag :chevy
It supposedly came out of a 69 Vette. I was hoping to find the numbers to ID the block as an original 427 before I go look at the engine ( its a 200 mile drive from my place ) so can someone tell me the numbers to look for on the block?
Old Sep 26, 2001 | 08:33 PM
Captain Morgan's Avatar
Captain Morgan
Cruise-In III Veteran
Cruise-In IV Veteran
Cruise-In V Veteran
68 427:
3916321
3935439
69 427:
3935439
3955270
3963512
And I don't think you'll see this as it is the ZL1 engine block but I'll throw the number out there anyway.
3946052
70 454:
3963512
Old Sep 26, 2001 | 08:50 PM
C3sharkattack
Default Re: Found a 427 (sharklover)
68 427:
3916321
3935439
69 427:
3935439
3955270
3963512
3946052
70 454:
3963512
Thank you for the information
Old Sep 26, 2001 | 08:58 PM
Detroit Vette's Avatar
Detroit Vette
I'll send you a check via next day service for $750.00. This offer is obviously pending confirnation that it is the real thing. And in case your wondering, yes this is a serious offer.
Old Sep 27, 2001 | 09:06 AM
BB2B's Avatar
BB2B
Default Re: Found a 427 (sdixon)
I have 427 engine I have recently decided not to use in my '69. If you are interested email me at gdanders@wnol.net. I was looking to get $1200 for everything I have but can be negotiable.
Old Sep 27, 2001 | 09:15 AM
BigBlockVette's Avatar
BigBlockVette
About 1 1/2 years ago, I paid $800. for a '69 block only, casting #3963512 with 4 bolt mains, standard bore (needing to be bored .030 over). At the time, I thought this was a good deal considering what was out there at the time.
Dwayne
Old Oct 2, 2001 | 03:37 PM
Dwaynes69BB
Hey Sharkattack,
how bout an update,
did you get the engine?
was is actually from a corvette??
To Found a 427
