OT: Taurus trans failure
These things are apparently shifted through a Powertrain Control Module
and someone suggested that the speed sensor may have failed. They also indicated the speedo would have quit if this happened, and it still registers. I'm out of my league here with the electronics and the lack of service manuals. Does anyone here have experience with these trannys and have any suggestions? Replacement (apparently no one repairs these things any more) would set me back around $2,750 at most shops. The car is in great shape mechanically, and in ten months the son is off to UVa and can't have a car on campus. But, of course, the value of the car is less than $1,000 (which is why the 17 year old is driving it) and I have to make a decision on whether to repair it or trash it.
I really don't want to buy a new (used) car only to inherit someone else's problems and then let it sit for a year 10 months from now, so I'm hoping this is a small problem.Any suggestions from Ford drivers? Thanks!
Steve
That being said, it is only a matter of time till either one goes out. I have already sought out rebuild kit for both and kind of hopes it happens when it is a little warmer.
It could be a great project for you and you son to put some buddy time on. My 15 year old daughter helps me out a lot. But she thinks she is building up credits to drive the vette in a couple of years.
Bill
anway, I am told they are fairly easy to rebuild, but to forget about the snap rings and fancy machine work in the older trannies I am somewhat familiar with....GM rwd vechocles....
apparently from comments, it's all held together with bent tabs and built super lightweight from stampings.....
but they DO sell kits for it, and with care they can be fixed....
another core supply place said to rebuild the original, as the choices of any/all FWD cars for things like specifics of electronic controlls, and internal gear ratios make it impossible to match a core to what I have....which is too bad, it would be worth 60 bux to be able to redo a core at leisure, and when time came, swap it out in an afternoon...
just like a tranny shop....but given the warnings, I find it chancy....
but I am a bit incredulous over the warning also, as I would think, logically, they'd want to make as few changes as possible to keep costs down....
Bernie
Bernie
Bill
I'm still hoping that this is something simple, like an electrical connection come loose, but I'm losing hope. Looks like it's gonna get it's butt hauled to a shop next week on a flatbed. Like I said, I'm too old to deal with this stuff anymore. Unless it's on a '74 Vette....
Steve
http://www.zbag.com/specials.html
They are a reputable gear shop in Zumbrota Minnesota.
They have a new tranny for a 01-03 Taurus for $750.00, don't know, might fit, they'll know.
Steve
Steve's74 first thing I would do is have the codes pulled. It is highly possible a speed sensor has failed. Some of them used mechanical gauges so the speed sensor has an electrical part and also has a cable. So it is possible to have a working speedo and a bad sensor. If you drive it with only first gear an extended amount of time you will probably end the hope of a simple fix. And it possible to have a trans code and not have a check engine light. They will also not flash a light. You will need to go and have a diag done.
I had a 93 Sable. At about 150,000 kms ( 90,000 miles ) one thing after another began to fail on it!I purchased it from my father in-law at 75,000 kms.The car was never driven hard but was going through starters, alternators,sensors and front end parts etc. Cut your losses and get rid of it!!!!!
Steve
Rick B.
Bernie
Bernie
Like I said earlier, lots of new parts, so it's mechanically sound. We'll see what the diagnosis is two weeks from now. Thanks guys.
Steve
Bill
Bill
