Removing Door Panel on 1973
Old Dec 7, 2006 | 07:08 PM
c3andc5's Avatar
c3andc5
Default Removing Door Panel on 1973
I need to remove the inner door panel so I can try to fix the rod mechanism connected to the handle. Can someone please give me some hints as to how to remove the door lock **** and the manual window crank? Are there clips holding those on? Do In need a special tool?
Old Dec 7, 2006 | 07:33 PM
...Roger...'s Avatar
...Roger...
Yes there is a special tool but if you make a hook out of a paper clip you can pull the clip out.(the tool pushes the clip)
Old Dec 12, 2006 | 10:02 PM
Duke94's Avatar
Duke94
To Removing Door Panel on 1973
