I am about to start assembly of my engine and had decided on going with a 383, but I have seen a few posts about being able to use a stock oil pan. Seems like some people are able to use stock pans and others can't. I am using a 9000 Scat crank with 6" rods. Can anybody give me the straight answer? Thanks in advance.
I had planned on using the 6" Scat Pro Com I Beam Rods mainly because it seemed that I would not have to do all of the grinding on the rod bolts. Any advice? Thanks
From: San Diego - Deep Within The State of CONFUSION!
I am using an Eagle stroker kit, with 6" H-beam rods. Moroso's 7-quart stroker pan worked fine for me.
