driveshaft
Old Dec 9, 2006 | 03:20 PM
mooty1's Avatar
mooty1
Default driveshaft
Installing driveshaft after putting new u joints in. does trans. yoke and diff. yoke have have to be 90 degrees from each other? thanks
Old Dec 9, 2006 | 04:17 PM
wombvette's Avatar
wombvette
Say what? On a 76, and I have to assume that you are working on a 76, you cannot change the relative positions of the yoke and pinion.
Old Dec 9, 2006 | 04:49 PM
...Roger...'s Avatar
...Roger...
No
Old Dec 9, 2006 | 07:03 PM
mooty1's Avatar
mooty1
Default yokes
Does trans. yoke and diff. yoke have to be in different positions?
Old Dec 9, 2006 | 08:07 PM
mooty1's Avatar
mooty1
Default driveshaft
Installed new u joints and pinion seal. while still jacked up ,drive shaft would turn easily by hand.Backed out of shop.In first gear clunking and feels like rear of car raises a little.Thought maybe position of diff. yoke and trans. yoke was wrong?
Old Dec 9, 2006 | 10:03 PM
wombvette's Avatar
wombvette
Still trying to figure out what you are asking. Do you mean the pinion yoke and the axle yokes at 90 deg. You could do that, but they dont stay there as soon as you turn a corner they change. You can put the driveshaft joke and the pinion yoke on one of four different ways, none of which will affect anything except maybe balance.
Old Dec 9, 2006 | 10:15 PM
mooty1's Avatar
mooty1
Default I don't know
I don't know what the hell i am talking about for sure! It just does not feel right when i idle along.Thought i heard something hitting.Thought maybe driveshaft was binding somehow thanks for the help! AL
Old Dec 9, 2006 | 10:23 PM
wombvette's Avatar
wombvette
When the car is jacked up, it is common for the axles to bind, but not with it down. Jack it up, the support the wheels under the shock mount. Then spin the assembly and see if you can detect anything wrong.
Old Dec 9, 2006 | 10:49 PM
...Roger...
Do you think you got all the u-joint cups seated in the yokes?Its easy to have one of the cups up on the end tabs.
Old Dec 9, 2006 | 11:02 PM
mooty1's Avatar
mooty1
I double checked before i got out from under it. I jacked it up this evening.Maybe tomorrow i will be able to see what is hitting
To driveshaft
