dwell meter question
Old Dec 9, 2006 | 09:01 PM
bondoboy's Avatar
bondoboy
Default dwell meter question
I bought an old auto meter dwell meter and was wondering how I hook it up. I assume one lead goes to a power source and the other goes to the point wire. I have never used one of these because my old vehicles either came with hei, or a previous owner had converted it to hei. I just want to make sure I don't hurt this tool because it's old and very nice. Thanks a lot.
Old Dec 9, 2006 | 09:08 PM
StickShiftCorvette's Avatar
StickShiftCorvette
The red lead goes to the + terminal on the coil. The other, usually green goes to ground....
Old Dec 9, 2006 | 09:23 PM
Gordonm's Avatar
Gordonm
On mine the green wire went to the - side of the coil and the black went to ground. I have not used it in years though.
The - side of the coil is connected to the points and senses when the points are open. Then you needa ground.
Old Dec 9, 2006 | 09:30 PM
bondoboy's Avatar
bondoboy
Mine has a red lead and a black one, any ideas? Should I write to auto meter? Can this gauge be damaged by hooking it up wrong? Thanks for the help.
Old Dec 9, 2006 | 11:10 PM
jamesc1123's Avatar
jamesc1123
I'm just a junior member, but red would go to the negative of the ignition coil, and black to ground.
Old Dec 9, 2006 | 11:52 PM
bondoboy's Avatar
bondoboy
Old Dec 10, 2006 | 01:52 AM
yukon988's Avatar
yukon988
That's how mine connects. But, my meter is relatively new. What color leads do you have?
Old Dec 10, 2006 | 07:29 AM
Jud Chapin's Avatar
Jud Chapin
St. Jude 15 Year Donor
St. Jude Donor '11 thru '25
The black should go to a good ground and the other to the coil minus terminal.
Old Dec 10, 2006 | 09:16 AM
StickShiftCorvette
There must be some differences between dwell meters. I put the black (or green) to a ground, but do recall that putting it to the "-" on the coil also works - just a little harder than using a ground.
I have not gotten readings putting the red to the "-" on the coil.
Old Dec 10, 2006 | 09:28 AM
kb2fzq's Avatar
kb2fzq
Try it both ways with the car running, when you get a dwell reading on the meter, that would be it.....easy
Old Dec 10, 2006 | 11:14 AM
SanDiegoPaul's Avatar
SanDiegoPaul
From: San Diego - Deep Within The State of CONFUSION!
On a Chevy V8, you really don't need a dwell meter. If you run the allen wrench clockwise until the motor misfires or stalls (whichever comes first), then back off exactly 1/2 turn you will be at 30* dwell.
Try it. It works!
Old Dec 10, 2006 | 04:45 PM
bondoboy's Avatar
bondoboy
I put the red lead to the neg. coil and the black to ground and it worked. Thanks for the help.
Old Dec 10, 2006 | 04:53 PM
Jud Chapin's Avatar
Jud Chapin
You da man!
To dwell meter question
