Crate motor recommendation
Old Dec 10, 2006 | 02:23 PM
Tankers's Avatar
Tankers
Default Crate motor recommendation
http://www.dpmpower.us/home.htm
I had read a thread here about a member having problems with a Year One motor and these guys from Derebery Performance who build engines for Year One traveled a hundred miles to his house to fix the motor and I thought that was some good customer service. So I decided to buy from them, it was a 3 hour trip each way to their shop. When I arrived my motor was on the dyno, they installed and adjusted my carb and dist. fired the motor up and I watched them dyno the motor which put out the advertised 400 HP. Then they tweaked my carb and dist and each time they ran the dyno again to see any improvements. Then we tried different carbs, each time a dyno was run to see which combo worked best. They showed me how they build the engines, showed me some of thier race engines. Outstanding support.
Old Dec 10, 2006 | 03:43 PM
72 LT1's Avatar
72 LT1
Sounds like you made a wise choice.
Old Dec 10, 2006 | 10:05 PM
Russ T Gate's Avatar
Russ T Gate
Excellent service, anytime you can witness first hand the performance of the product your going to buy, your way ahead of the game.
Good luck
Russ
Old Dec 10, 2006 | 10:17 PM
vetteguy75's Avatar
vetteguy75
LA Events Coordinator
I'm looking at getting a crate engine.....definitely going to check out these guys. I live in Shreveport about 4 hours from them....
To Crate motor recommendation
