TPI was s/d in 90, 91...92,93 were lt1, s/d...you can run any TPI as s/d if you tee a vacuum line and hook in a maP sensor.
and any lt1 intake will run with a maF sensor in front of it.
gotta use the matching ecm/prom
What he said. I would run it as Speed Density. Just add a MAP sensor and go.
What are the benefits of the Speed Density setup over MAF? Is it worth it to convert a system already in place or is it just easier not to have the MAF sensor?
s/d is easier to build a harness for (fewer wires), no burn-off relays like the maF needs, no space req'd for the maF sensor...the maP -727 ecm can be located under the hood (more convenient for wiring and chip changes) whereas the maF -165 ecm must be ''indoors''
my car ran .1 quicker 1/4 mi with maF than maP, both with generic aftermarket chips...( i have yet to get into burning my own chips, can't comment on what that would give)
Okay...all great info. Now, another aspect. TBI. Do you agree that when getting into the high RPM 350s and bigger cube small blocks that TBI is the way to go? I abandoned my TPI 400 project because I was told the TPI couldn't give the motor enough fuel / air at higher RPMs and that the TBI could be tuned better for bigger cube motors.
The desireability of TPI over TBI depends on the end use you intend - street (usually lower rpms) or street/strip (larger displacements/higher rpms). TBI can be sized to pass more air to feed more displacement and/or higher rpms than TPI (which was designed for 305 c.i. displacement engines.
TPI excels in low and mid-range torque, providing better response than the wet-flow TBI, and better economy as well. A well designed 350 TPI, with vortec heads, matching base, enlarged runners, ported plenum, larger throttle body, upgraded injectors suitable ccustom chip, and upgraded roller cam will produce enough torque and responsiveness to equal a similarly equipped carburated 383 on the street and will produce much better fuel economy
tBi is great if you want a carburetor than blows the gas into the air stream rather than sucks...really a great improvement in cold start and reduced fuel consumption, great low end power....however, upper end performance is limited by the problems inherent with similar style carb manifolds, even with a 454 throttlebod....i 'suspect' that tBi could do some good numbers, especially TWO throttlebods on a dual-quad carb manifold (wish i had time to get into that)...but lt-1 intakes (modded to fit sbc-1) are an already proven performer, good on 400+ c.i. engines to over 6k--a dizzy and a tpi ecm and hang on
That's what I'm doing. LT1 on a Gen1 block. I suggest TBI or even TPI to anyone wanting a cheaper add on EFI.
over the last few months, tBi prices have gone up to lt1 intake prices around here, seems the ferd guys use the throttlebod on an adapter plate + a HEI with ferd bottom/drive (china made for $100) to do EFI the ez way...tPi prices are still high because it IS a cool looking deal on street rods and works good for cruising...can't give holley carbs away.
So your saying if I come across a TBI manifold and carb I should hang on to them like stock with Microsoft? I was thinking of finding a big block TBI setup for a future maybe. What GM trucks came with the big block TBI?
tBi's/big blocks are occasionaly found in pik-ups and suburbans, from mid-80's and newer...word is out that GM tBi is ez install and works.
i will not advise anyone on what stocks to buy or girls to marry
