Another Angle Plug Thread
Old Dec 14, 2006 | 05:53 PM
dgruenke's Avatar
dgruenke
Default Another Angle Plug Thread
I have seen many posts about people glad that they went with the angle plug heads because they don't think straight plugs would work with the headers. My question is, if I get angle plug heads, will they work with the stock manifolds? I am interested in using the stock manifolds for the engine break-in.
Old Dec 14, 2006 | 06:25 PM
Roadster71's Avatar
Roadster71
Yes...I use the stock CI ram horns on my zz4 with no problem
Old Dec 14, 2006 | 07:47 PM
Gordonm's Avatar
Gordonm
My straight plug AFR heads work with my 1 3/4 Hooker headers just fine. Yes angle plugs should work fine with manifolds.
Old Dec 14, 2006 | 08:09 PM
panchop's Avatar
panchop
the fulie heads are straight plug...
Old Dec 15, 2006 | 10:03 AM
dgruenke's Avatar
dgruenke
So, both angle plug and straight plug heads will work with stock manifolds and headers?
Old Dec 15, 2006 | 10:17 AM
Gordonm's Avatar
Gordonm
Yes that should not be a problem
Old Dec 15, 2006 | 12:14 PM
MonzaRedConvert's Avatar
MonzaRedConvert
That's not necessarly true. I ran into problems with my Hooker Comps (bought from Gordonm) and Edelbrock angle plug heads. Several of the plugs are very close and #6 is just impossible. I could have put a dimple in the tube for clearence, but I'd rather not damage the ceramic coating. I ended up making spacers out of 1/2" aluminum plate to move the header away from the head. Now it just clears.
I think it depends on the header design. I had an old set of Blackjack headers with GM turbo heads that had no clearence problems.
Old Dec 15, 2006 | 02:23 PM
dgruenke's Avatar
dgruenke
Did you try the shorty plugs before you made the spacers?
Old Dec 15, 2006 | 02:25 PM
Gordonm's Avatar
Gordonm
I did not see the part on manifolds and headers, Yes some headers will have a problem with angle plugs. My AFR heads are straight and both the 1 5/8 Hooker Comps and 1 3/4 Super Comps did not have a problem. There are some tight plugs and wires and it takes some creative wrenching to get them out but they did fit. I have never had a set of angle plug heads with headers.
To Another Angle Plug Thread
