1980 L82 Engine Upgrade
Old Dec 14, 2006 | 06:04 PM
pbronson's Avatar
pbronson
1st Gear
Default 1980 L82 Engine Upgrade
I have a numbers matching 1980 L82 in good shape but I want more HP and torque. As I am new to the hobby I am wondering if I should upgrade the current engine or save it and put in a new crate engine. I don't know if messing with the existing engine would reduce the value of the car of if that is even a consideration. Any comments would be much appreciated.
Pete
Old Dec 14, 2006 | 06:47 PM
marshrat99's Avatar
marshrat99
You'll get lots of contrasting opinions on this one. For me, I yanked & stored my numbers matching 79 L82 engine and built myself a custom 355. I did the build route vs. crate simply because I wanted to learn about building engines. I ended up spending more money vs. crate but the education was worth it IMO. Next time and there will be a next time, I'm going the stroker or blower route but didn't know enought the first time thru. I really don't give a darn about numbers matching but some do.
Old Dec 14, 2006 | 06:56 PM
Little Mouse's Avatar
Little Mouse
put the engine in the corner of the garage and buy a crate engine.
Old Dec 14, 2006 | 07:10 PM
rumpity_z28's Avatar
rumpity_z28
3rd Gear
Great idea! I picked up a motor out of the wreckers (pick your part) out of a 88 caprice,the block has the roller provisions so going with a roller setup is way cheaper.My friend used it in his 1980 z28 and put his stock numbers matching LM1 in the corner,no morry worries of trashing the stock motor.
To 1980 L82 Engine Upgrade
