Scuff or strip?
Old Dec 14, 2006 | 07:02 PM
marshrat99's Avatar
marshrat99
Default Scuff or strip?
I think I know the answer but after several years on the Forum I value your advise. My 79 is currently black and who ever painted it didn't do that good of a job. I also don't like having to keep it all that clean. Therefore on my "to do" list this winter is paint. My best friend's father paints cars on the side and says that I don't need to worry about stripping off the old layers of paint (I don't know how many are there) and says that all I need to do is to scuff up the old paint and have at it. Problem is that I've seen several of his paint jobs and they're not much better than where I'm at now. IMO if I'm going to go thru all that much effort then I'd like to end up with something that I'd be proud of.
The question for my Forum Brothers & Sisters is scuff or strip?
Old Dec 14, 2006 | 08:56 PM
DR.Jay's Avatar
DR.Jay
Strip it down. It's a time consuming job, and is pretty messy (if done with chemical strippers), but well worth the trouble because you'll know what you have under the old paint. As has been posted numerous times "the paint is only as good as the preperation"
Just MHO.
DR. Jay
Old Dec 14, 2006 | 10:03 PM
big_G's Avatar
big_G
Just MHO.
DR. Jay
Old Dec 14, 2006 | 10:22 PM
MYBAD79's Avatar
MYBAD79
St. Jude Donor '05
Your '79 body is SMC, that's not as sensitive as fiberglass when it comes to chemical stripper. I only used stripper in a few areas where I couldn't get the razor blade to bite (mostly curves, fender opening, doorjambs).
Stripping with a razor blade is easy and not as messy as stripper
It doesn't take too long either, the entire car can be done on one weekend - it took me about two weeks because I get distracted too easy
Old Dec 14, 2006 | 10:25 PM
Jud Chapin's Avatar
Jud Chapin
St. Jude 15 Year Donor
St. Jude Donor '11 thru '25
If you don't strip it, you run the risk of the new paint job not lasting, especially since it has several layers of paint on it now.
Old Dec 14, 2006 | 10:33 PM
millermilitary2000's Avatar
millermilitary2000
I have been researching methods of stripping my 69 Vette and have decided to have it media blasted. It should cost about $700-900. They said they can put two coats of duct tape to protect any trim or glass left on the vehicle.
Perry
To Scuff or strip?
