OK...static compression question
Old Dec 14, 2006 | 07:21 PM
luerja's Avatar
luerja
Default OK...static compression question
Here's the setup.... 350 standard bore 3.48 stroke inverted dome -24cc pistons and fast burn aluminum heads 62cc combustion chambers? What might be my static CR?
not looking for exact figures here but something to go on so i don't have to send 1500.00 on new heads and invest that money in a 5 speed.
All opinons welcome.
Jim
Old Dec 14, 2006 | 07:32 PM
MotorHead's Avatar
MotorHead
From: Who says "Nothing is impossible" ? I've been doing nothing for years.
Old Dec 14, 2006 | 07:34 PM
luerja's Avatar
luerja
Originally Posted by MotorHead
8.673
I think that might work for a while? I just have to figure boost ratio to keep it under 12% or at least 7 lbs boost.
Thanks MotorHead his gives me hope
Old Dec 14, 2006 | 07:42 PM
MotorHead's Avatar
MotorHead
8.673 with standard deck height ( .020" in the hole ) and .038" thick gasket with 4.10" holes in it
Old Dec 14, 2006 | 08:11 PM
luerja's Avatar
luerja
Deck is standard ..as it is a GM crate motor with 7k miles on it. gasket can even go up to .051 i guess
Old Dec 15, 2006 | 09:40 AM
jackson's Avatar
jackson
Jim
OK, std deck ... BUT what is compression distance/height of -24cc pistons? ... probably in range 1.540"-1.565" ... Also, which gasket P/N do you expect to use. I know you said not exact, but 0.025" here & there WILL make alotta diff in scr.
To OK...static compression question
