Guys, The horn on my recently purchased 76 with T/T steering wheel wasn't working. Pulled the horn pad off, looked inside and found what appears to be the contact pin? ( about 1" long with a small head on it) a spring and a 1/4 inch plastic sleeve laying at the bottom. How does this fit together and go back into the hole?
Also, how do you go past the "30 days" of archives on here?
Thanks for the help in advance!
Thanks for the help!!! I was wondering about that little pin on the plastic sleeve!!! Will put it together tonight. Let you know how it works!
Mike
PS, What about going past the 30 days archives? I've tried everything!
