AC Compressor Conversion - Sanden
Old Sep 27, 2001 | 11:05 AM
lvrpool32's Avatar
lvrpool32
Default AC Compressor Conversion - Sanden
I am thinking about changing the factory 1969 AC compressor to a sanden unit....basically because I want to use the matching billet brackets that I have on my alternator and Power steering....I would like to do it so that could easily go back to the factory unit in the future.
anyone ever done this? difficult?
cheers
Nick
Old Sep 27, 2001 | 01:47 PM
BSeery's Avatar
BSeery
From: Exiled to Richmond, VA - Finally sold my house in Murfreesboro, TN ?? Corner of "Bumf*&k and 'You've got a purdy mouth'."
CI 6-7-8 Veteran
CI-VIII Burnout Champ
St. Jude Donor '06-'10, '13
Default Re: AC Compressor Conversion - Sanden (lvrpool32)
ttt
Old Sep 27, 2001 | 03:10 PM
Wrencher's Avatar
Wrencher
Sounds like a good plan. It would be shorter than an A-6, thus allowing more room! Are the billet brackets set up for the stock mounting position? I'm refurbishing my system now and still need to buy the original mounts, some of which aren't available anymore. I have a good A-6, which is a great compressor, so I'd have to decide. How much were the billet brackets?
Hans
Old Sep 27, 2001 | 05:44 PM
Smokehouse69's Avatar
Smokehouse69
Cruise-In VI Veteran
Cruise-In VII Veteran
Nick,
It should be a neat conversion, the Sanden unit is lighter and probably more efficient. The only thing that should be a little problem will be the hoses, but they shouldn't be too hard to find. Good Luck! Post some pictures when you get it in.
Old Sep 27, 2001 | 11:02 PM
flynhi's Avatar
flynhi
Default Re: AC Compressor Conversion - Sanden (Smokehouse69)
I suggest that you check with Vintage Air in San Antonio or Street and Performance in Mena, Ark for brackets, hoses, etc.
Old Sep 28, 2001 | 05:24 AM
mrvette's Avatar
mrvette
I did the conversion to late model compressor and serp drive some time ago in my '72, I recommend it....the hoses need redone by a GOOD a/c shop....I say a good one can look in a book, find the hose barb kit for the compressor, the fittings for your car, and route hoses by tape measure, go into the shop and swage them up....done...cost about 125 bucks or so...total...kinda expensive, but not any much more than stock hoses....call around, if they don't have the ability to swage hoses for themselves, they not a good a/c shop....period....
GENE
Old Sep 28, 2001 | 05:13 PM
lvrpool32's Avatar
lvrpool32
Well I have found the Sanden compressors going for $219 polished.....then a "hose" kit with drier for $150.
I have some billet aluminum plate, which I am going to copy the factory style brackets, I will just adjust where the mounting holes are located, to line up with the zoops bracket ( I will also have to make a 3" dowel piece to allow for the diffence in lengths of the compressors).
I guess there is no harm in trying.....and if it doesn't work I will go with the Sanden.
Nick
Old Sep 28, 2001 | 05:22 PM
74-Roadster's Avatar
74-Roadster
St. Jude Donor '06
Father & Son St. Jude Donor '09
Where did you find them?
Old Sep 28, 2001 | 06:24 PM
Tom73's Avatar
Tom73
Check with Chris Petris of Corvette Clinic down in Fla. He has, or did a couple of years ago, a kit to do what you want.
tom...
[Modified by Tom73, 4:25 PM 9/28/2001]
Old Sep 29, 2001 | 09:15 AM
MassVette's Avatar
MassVette
I've been trying to get my Sanden hooked up on the ZZ/502 in my '79--
Called Vintage Air-----got a runaround; S&P says "just go to local rad shop--yeah, right; they won't TOUCH it. ANYONE know what parts are needed to adapt?????
:chevy :yesnod: :chevy
Old Sep 29, 2001 | 09:31 AM
mrvette's Avatar
mrvette
Default Re: AC Compressor Conversion - Sanden (MassVette)
Masvette, like ai said before, you need call around your area and find an a/c shop with the capability of swaging hoses for themselves, they can order the fittings and fabricate what you need on site....only way to get it done...
the hoses for my '72 won't work on your car, as the fittings on the evap side are differant...maybe even on the condensor side too....
MY hoses loop around in front of the compressor on the evap side...on the cond side it's a direct shot with about 12" of hose....it's due to the fittings available and flex requirements and hose length/diameter....it's a neat instalation, better than anything I came up with on my own....
GENE
Old Sep 30, 2001 | 11:39 AM
spikezz4's Avatar
spikezz4
Ivrpool32: The Corvette Clinic in Sanford, FL still sells the Sanden compressor in a complete kit. The number is 407 323-7328. Ask for Chirs or Hope and tell them Spike said to call.
Spike
To AC Compressor Conversion - Sanden
