No rear brakes
Old Sep 27, 2001 | 02:35 PM
emsrescu's Avatar
emsrescu
Default No rear brakes
I have changed the master cyc and i have no rear brakes still. I have fluid and the brake pads move but they have no pressure. It's on a 77 is this a common problem? I have a proportioning valve on order.
Old Sep 27, 2001 | 03:10 PM
R. Bruno's Avatar
R. Bruno
Default Re: No rear brakes (emsrescu)
What have you done in the way of bleeding master cylinder and calipers?
Old Sep 27, 2001 | 03:17 PM
emsrescu's Avatar
emsrescu
I have changed the fluid and bench bleed the master cyc and bleed out the calipers per the book.
Old Sep 27, 2001 | 03:19 PM
R. Bruno's Avatar
R. Bruno
What was the original problem? No rears only?
Old Sep 27, 2001 | 03:21 PM
71coupe's Avatar
71coupe
If you don't see any leaks anywhere, you have air in the system.
You should re-bleed the brakes.
:cheers:
Old Sep 27, 2001 | 03:33 PM
emsrescu's Avatar
emsrescu
Default Re: No rear brakes (71coupe)
No rears was the problem. I get fluid only no air when i bleed the system. I have put 1 whole quart of fluid through the system so there can't be any air.
Old Sep 27, 2001 | 03:57 PM
454Big's Avatar
454Big
How old are you flexible lines?
Perhaps they have detoriated and prevent the fluid from building up pressure?
Please post what you have replaced in your system..... :confused:
Old Sep 27, 2001 | 04:21 PM
ORVette's Avatar
ORVette
Default Re: No rear brakes (454Big)
Really dumb question time: are you bleeding both sides of each calliper?
Old Sep 27, 2001 | 04:44 PM
71'AirStrike's Avatar
71'AirStrike
I had a similar problem with my 71'. I used Vaccume pumps to suck fluid through. Hoses attached to the caplar nippels going into a jar filled with brake fluid while pumping the brake pedal. Pumping the brake pedal 3 times while a friend realeses the pressure until No air came out of the hose. I can honestley say that I went through 3 quarts of fluid and 3 packs of smokes in frustration. However nogthing worked for me.
The style that finally worked for me was.........taking it to a mechinac.
now it works great.
The mechinac did not replace anything. I think he was better skilled at crushing gremlens than I was.
Old Sep 27, 2001 | 05:08 PM
R. Bruno's Avatar
R. Bruno
New master cylinder or rebuilt? Does the pedal still go to the floor or is it somewhat firm? It really does sound like air in the system if the m/c is good. Unusual I think for just the rears not to be working.
Are all the hard line connections tight? I had a problem once where a connection was not and it was sucking in air and had no fluid leak because there was not enough pressure in the line.
Old Sep 28, 2001 | 08:58 AM
emsrescu's Avatar
emsrescu
Default Re: No rear brakes (R. Bruno)
I've tryed about everything so far. I have been bleeding the inside and outside bleeders. I took off the proportioning valve and have one coming in today. When i took off the top sensor on the proportioning valve it had this valve that looked to be blocking the back line i was able to reset it with a small screwdriver. I will see if this fixes it after work. I also put plugs in the master cyc and tryed to push the brake and it was solid. the master cyc looks to be ok. It is a new bendix. Will keep you all informed thanks for the help.
Old Oct 2, 2001 | 09:54 AM
emsrescu's Avatar
emsrescu
Well i changed the proportioning valve ( not it ). rebuilt the rear calipers, I recomend changing them next time. One blew so i replaced them and guess what now i have rear brakes. I still have a problem with the pedal when i start the motor the pedal goes almost all the way to the floor. When the motor is off the pedal is solid. I'm not losing fluid and the brake hoses look good. Any ideas?
To No rear brakes
