I got my frame back from powder coating a couple of weeks ago and am slowly getting parts back on it. I've just gotten to the studs that the upper control arms bolt to. These studs have teeth (knurling?) that should fit into the holes so the bolt doesn't turn while tightening the nut since the head is difficult to get to with the control arm in place.
I've found that the holes in the frame and the associated teeth are covered in powder coating to the point that you can barely tell there are teeth in there. I'm having a very hard time getting this area cleaned out so the bolts will go in.
Anybody know of a good way to get these holes cleaned out?
You should be able to drill the holes out if you can get a drill bit with the same diameter as the hole but as for the teeth I would say a lot of time and triangle file are your only hope.
I also just about powdercoated everything on my vette. Had to clean a compleet crossmember because it needed some welding and a recoat.
The best thing to do is buy a nice and cheap liquid paint stripper. Put it on the places you want cleaned and wait about 5 minutes. Now the powdercoat is almost liquid and its very easy to scrape it of. If its a inner tread you need to clean. Do the same and put the bold in after 5 minutes. Very easy also to get the powdercoat of the points where your groundcables will connect to the chassis
Try to tap in the bolts, you should be able to drive out the paint with the splines of the bolt. If it sounds like you're hitting metal, slightly rotate the bolt and try again.
This is the reason why you should plug/tape off everything you do not want coated.
I specifically asked the guys if there was anything I needed to do to the frame before bringing it to them and was told that I didn't need to do anything. I was also told previously that they would put body mount bolts in their associated holes to keep the powder out of those holes but don't see any evidence of that having happened. I'm gonna have to tap those holes I guess but there doesn't seem to be a nice clean way to clean out these holes.
I tried taping the bolts in and attempting to line up the teeth right but that doesn't seem to work. It looks like it will wear down the teeth on the bolt before the powder coat moves.
I'm concerned about using chemicals here due to not wanting to remove any more powder coating than necessary but may have to resort to that.
I had to weld something that was coated once, the part to weld was raised and I could easily grind the coating off and weld on it, thinking i could easily touch up the now bare ground section with some por and never see it...big mistake, the heat destroyed the coating in a large circumference that's the only major drawback to a coated frame, that's why mine is taking so damn long, I have to weld everything in place, attach all brackets and what not..basically mocking up the entire car before taking it to the coaters...afterwards I'll be stuck with what I have.
The whole frame coating process seems overkill to me, unless it's destined to be a show car. How do they refinish the inside of a frame? Can't be done as far as I know.
refinish? no need to dip the frame, you can sandblast it. However if you dip it, it can also be galvanized (check for straightness afterwards) and then iron phosphate treated and coated (without the phosfate coating won't stick)..even better than flame zinc spraying.
Zip Strip will remove Powder Coat, just be patient and use 2 or 3 times on an area it will soften and come right off. Straight Acetone also.
I was with the notion that powder coat was resistant to chemicals like acetone and lacquer thinner. Recently, I was cleaning a lower control arm with lacquer thinner that was supposed to be powder coated. After some wiping, I started to see a white base or sandblasted finish showing through. I stopped wiping, so I am not sure which. My conclusion was that the powder coat was probably a nice coat of Rustoleum that was coming off. Could I have been wrong in my conclusion and powder does break down when exposed to lacquer thinner and acetone?
Zip Strip comes in industrial strength, use it and some patience. It will melt it wipe off and the edges will tend to feather themselves. It is tougher than paint to remove. Most all of my metal parts are powdercoated, frame/chassis, interior aluminum panels etc. The real strength of powder coat is resistance to scratching and abrasion, generally it's paint, just alot tougher. I also have found paints that match my powder coat colors to touch up areas I have had to remove coatings, no matter how well you plan you will move or remount something eventually. Good powder coat prep means plugging all the holes that are threaded or have tight tolerances, generally you will do a better job of this than the powder coater as he wiil not know which areas are important, I learned this lesson late. Industrial Zip Strip and a Q-Tip
Try to pull the bolts in. Get a spacer and use the nut to draw it in. As you pull it in hilp it along by hitting the head of the bolt. Also be carefull with brake fluid around powder coat it will eat it up. I stick with POR 15. Once powder coat gets a nick or scratch the rust will erode under it and it will start flaking of.
