Why high octane gas rather than octane boost ?
Old Dec 18, 2006 | 11:04 PM
68/70Vette's Avatar
68/70Vette
I once bought a L88 short block from GM. I had the piston domes milled off a little to get the stock 12.5:1 compression ratio down to 11.5:. I used the iron rectangular port heads. I mixed 5 gallons of AV gas and 15 gallons of the highest octane pump gas at that time. The engine ran fine. It would not run on straight pump gas without pinging. I started buying AV gas for the car by taking 5 gallon Jerry cans to the airport. Once the people at the airport got to know me, I could drive the car there and they would pump gas directly into the car. For a long trip I would fill the tank with 100% AV gas, and then as I drove and burn, say a 1/4 of a tank off, I would pull into a gas station and top the tank with car gasoline. This way I could go a long way with AV gas enriched gasoline.
Also, even with an L88 like clone engine, with it's L88 cam, and with Hooker headers and a 3.08:1 rear end gear ratio, I got good gas mileage. I could drive the 300 miles from Torrance Ca (new LAX) to Las Vegas on one tank of gasoline.
Old Dec 18, 2006 | 11:48 PM
Jim_Harrison's Avatar
Jim_Harrison
I've been mixing about 20% 110 leaded racing fuel with pump premium in my 70 LT1. Stops any knocking and the plugs look good. Wonder if anyone else is using this pain in the tank way. I've been told switching to aluminum heads will stop the need for leaded fuel.
Old Dec 28, 2006 | 03:54 AM
noisy_mouse's Avatar
noisy_mouse
Is it legal to run leaded on the street ?
I'm going to have a car with high compression which requires leaded gas, and I'm even thinking to reduce CR with sacrifucing the power.
Old Dec 28, 2006 | 09:48 AM
C3 4ME's Avatar
C3 4ME
I think all cars should run racing gas, especially the ones in front of me. You know you're a car nut when you say that just because you love the smell of the racing gas.
