speedometer question
Old Dec 18, 2006 | 08:59 PM
bondoboy's Avatar
bondoboy
Default speedometer question
My speedometer quit working. I spun the cable with a drill and still nothing. The cable spins freely. I can eliminate a problem in the transmission speedo drive. I could not pull the cable out of the sleeve. Sometimes if the cable breaks, it will pull out. Is there any part on these speedometers that is prone to break? Thanks for the help.
Old Dec 18, 2006 | 09:10 PM
...Roger...'s Avatar
...Roger...
The cable has to come out the top.Did you push the cable in all the way when you used the drill?
Old Dec 18, 2006 | 09:34 PM
bondoboy's Avatar
bondoboy
I tried pushing and pulling on the cable and it wouldn't move.
Old Dec 18, 2006 | 09:53 PM
...Roger...
No I meant when you were turning it with the drill did you make sure it was in far enough to engage the back of speedo.edit -also to get the cable out you have to remove it from the back of speedo-the cable comes out from that end-it has a ferral on that end.
Old Dec 18, 2006 | 10:26 PM
bondoboy's Avatar
bondoboy
I tried pushing it in toward the speedo, but it didn't move. I guess I should take the gauge out and see what's going on. Thanks for the help.
Old Dec 18, 2006 | 11:05 PM
...Roger...
I usually just reach up and release the cable from the back of the speedo.Then I spin the brass input to the speedo and watch the needle.Sometimes when they break the break is above the ferral.In other words just the 1" flattened end that goes in the back of speedo.The good part of that if that happens is the speedo is still good-the bad part is you usually have to remove the speedo to get the 1" piece out.
Old Dec 18, 2006 | 11:26 PM
Artsvette73's Avatar
Artsvette73
Did you use a reverseable drill? They have to be spun counter clockwise
Old Dec 19, 2006 | 02:43 PM
bondoboy's Avatar
bondoboy
Thanks for the info. I spun the drill both ways and nothing happened.
To speedometer question
