Under hood wiring harness
Old Dec 19, 2006 | 01:36 PM
richardttu's Avatar
richardttu
Default Under hood wiring harness
I need to replace all of the underhood wiring harnesses on my 68 coupe (engine, AC, and forward lamp harness). Has anyone done this and could someone offer some pointers, or maybe a good reference book? I have the assembly manual, but it does not really provide all of the info I am afraid I might need to accomplish this. It runs now, and I would hate to be left with a non-running car due to some error on my part.
-Richardttu
Old Dec 19, 2006 | 02:11 PM
Easy Mike's Avatar
Easy Mike
Cruise-In II Veteran
Personally, the AIM has the best diagrams of how to route the harnesses, plus where the various end connections are and where they go. The wiring diagram in the '68 AIM is pretty good for tracing wire colors and sizes. Stick with the AIM and you can't go wrong.
How are your fiber optics? The OEM fiber optics are part of the forward lamp harness. If your FO are otherwise okay, you can purchase a replacement forward lamp harness without the fiber optics and reuse your existing outfit. It's a bit tedious to separate the FO from the forward lamp harness, but it can save you a little money.
Old Dec 19, 2006 | 02:43 PM
Edzred72's Avatar
Edzred72
Originally Posted by richardttu
I have the assembly manual, but it does not really provide all of the info I am afraid I might need to accomplish this. -Richardttu
YES...the AIM has all the wire harness routing, just not on consecutive pages. You will have to flip around the pages a bit, but it does show everything.
Take notes, draw pics, and take pics of everything before you remove the old.
Eddie
Old Dec 19, 2006 | 03:15 PM
682XLR8's Avatar
682XLR8
Pay speacial attention to where the grounding points are located. The AIM shows where the all are
Old Dec 28, 2006 | 04:05 PM
richardttu's Avatar
richardttu
Thanks for the advice. This will be my major winter project on the car. I have to set aside my fears and do it, because someone has really hacked it up.
Old Dec 28, 2006 | 07:40 PM
Duke94's Avatar
Duke94
Also, label the connectors as you take them out so you know where the new ones plug in. Use a camera too. The 3 harnesses you refer to are not complex and are easy to change. Also, we are here to help.
Old Dec 28, 2006 | 10:09 PM
68/70Vette's Avatar
68/70Vette
I would suggest taking a lot of photos of the harness (with all the dashs removed). Also. Dr Rebuild is now selling photo representations of the harness and their connectors. His photo representatinos of the connectors are very helpful. Also Don Olson, a forum member, sells color wiring diagrams that are very nice. When you're doing wiring work, you just can't get too much help!!
Old Dec 28, 2006 | 10:19 PM
Frank O'Hara's Avatar
Frank O'Hara
I just replaced all 3 harness's (forward lamp, engine and AC). I used LectricLimited and it worked out great. I replaced one harness at a time ( I made sure the car started after each harness) and left the AC harness for last since if was a challenge getting to it behind the dashboard. I used the AIM and it was great... a bit challenging but good. I also used a Corvette Fever article that walked thru it step by step - they had a few good pointers
Old Dec 28, 2006 | 10:23 PM
69 Vette's Avatar
69 Vette
Frank, can you tell me which issue of CF? Im about to do my under dash, AC and engine harnesses.
thanks!
Old Dec 28, 2006 | 10:48 PM
The Spark's Avatar
The Spark
Lectric Limited has great harnesses. I also got the laminated wiring diagram and put in on the wall next to my car. Between it and the AIM I had no problems replacing the engine compartment harnesses.
Old Dec 28, 2006 | 10:55 PM
69 Vette's Avatar
69 Vette
Good to know. I just ordered my harnesses from lectriclimited
Old Dec 29, 2006 | 01:46 AM
68RATVT's Avatar
68RATVT
[QUOTE=richardttu;1558168180]I need to replace the all of the underhood wiring harnesses on my 68 coupe (engine, AC, and forward lamp harness). Has anyone done this and could someone offer some pointers, or maybe a good reference book? I have the assembly manual, but it does not really provide all of the info I am afraid I might need to accomplish this. It runs now, and I would hate to be left with a non-running car due to some error on my part.
Richard,
I was a bit mortified also, I took good pictures,used masking tape to label the ends and routing points. After I got the engine harness out, I laid it on the floor spread out sort of like in the engine compartment. It's not hard, go slow and try not to be interupted by the phone.
Old Dec 29, 2006 | 07:18 AM
markdtn's Avatar
markdtn
Originally Posted by 72vette_454
Lectric Limited has great harnesses...
and Last Detail has the best prices on their harnesses.
Old Dec 29, 2006 | 09:58 AM
Frank O'Hara
thanks!
Corvette Fever September 2006
Old Dec 29, 2006 | 10:45 AM
69 Vette's Avatar
69 Vette
Thank you!
Old Jan 4, 2007 | 02:45 PM
richardttu's Avatar
richardttu
Thanks everyone. I have the CF article, and ordered the harness from Lectric Limited. I have also just ordered the two 1969 wiring diagrams from Doc rebuild. Hopefully these, and the AIM and a CD full of pictures will be enough to get me by. But looking at the current harness will be little help, as it has been completely hacked up (at least 6 wires to the alternator, AC wiring cut at the compressor, several cut wires that go nowhere, missing fusable links etc). Bubba has struck again.
I hope to start with it in a couple of weeks, will let you know how it goes. I just hope i do not wind up with a car that does not run
Old Jan 16, 2007 | 02:55 PM
bwellisley's Avatar
bwellisley
do you plan to do the installs with the body on? keep us posted on how it goes. i just ordered all 4 harnesses for my 68 and plan to start soon also. thanks
To Under hood wiring harness
Old Jan 17, 2007 | 09:50 AM
richardttu's Avatar
richardttu
I plan to do it body on, engine in, fingers crossed, and hoping for the best. I currently have a couple of projects at work consuming even my spare time, but they should be wrapped up in a month or so. So, I will be delayed a little. I will keep everyne posted (unless it goes horribly wrong, then I will hide my shame and sulk quietly)
What is really sad is that I am an electrical engineer, with a graduate degree in physics, yet looking at the rats nest under the hood seems so intimidating for some reason. Maybe its because it is all hacked up.
Richard
Old Jan 17, 2007 | 10:39 AM
bwellisley's Avatar
bwellisley
Sounds like our cars are in the same boat
Lets keep in touch as we go through it. Mine is also hacked-up beyond recognition.
I'm thinkin of tryin' to post a follow-along thread with all my photos and issues. I just need to find a place to host photos.
I'll send you a PM too.
Old Jan 17, 2007 | 01:58 PM
68 NJConv 454's Avatar
68 NJConv 454
I use www.photobucket.com, you can create albums and organize your pics, also makes it very easy to post pics/vids on this forum.
Search "doogiePBJ" and you'll find my albums
