Down to the wire on cam selection
My set up: Eagle 383, 9.5 SCR, alum heads with 190cc runners and 64 cc fast burn chambers, performer intake, quadrajet, ram horns, with 2.5inch pipes exiting through a pair of Magnaflows, TH400, Hughes 2500 stall convertor, and a 3:08 rear.
Objective: good all around cruiser, more performance, run on 87 or 89 octane and have a little thump to it. This car was a pig when I got it. wouldn't even spin the tires....
My Cam Choices:
1) Comp Retro Roller XR-270 with 218/224 duration @ .050, 495/503 lift, 110 LSA
2) Comp Retro Roller XR-276 with 224/230 duration @ .050, 503/510 lift, 110 LSA.
As always... different points of view are appreciated. Mark
My Cam Choices:
1) Comp Retro Roller XR-270 with 218/224 duration @ .050, 495/503 lift, 110 LCA
2) Comp Retro Roller XR-276 with 224/230 duration @ .050, 503/510 lift, 110 LCA.
A big concern is vacuum to run the lights, brakes etc
The bigger duration will give you the thump your looking for and the 112 LSA will help it pull at a lower RPM. Will work great with the 3.55 too. Upgrading the rear gear to 3.55 will make a very noticable difference in your acceleration and enhance all the other upgrades.Last edited by 63mako; Dec 19, 2006 at 11:41 PM.
My Cam Choices:
The XR 276 (224/230 on a 110 LSA) is 8.76:1 DCR
I had to call Comp to get the intake valve closingtiming numbers ABDC @.50
So it looks like both cams are above the 8.5 DCR threshold
thanks to everyone for their help, Mark
I would go the 2nd cam listed,might think about the XR 280,230/236 on a 110,you have to rememeber this a 383 and a XR 276 in 383 will seems small because of your cubic inches.A XR 280 Is really the smallest I would use.
270HR = 7.85:1
276HR = 7.70:1
Dynoed 280 rwhp @ 5200 315 rwtq @ 4100
The rams horns will not allow those larger cams to breath. Mine clogs up @ 5100. Headers would give 40+ hp/tq over beat up duals.
W/stk converter and 3:08 IT WOULD BE A DOG
the 1.6 RRs will run cooler, add lift, add very little duration.
Add comp to get 10.25, get smaller cam or 3:55 gears
This engine pulls like BB after 3K
JMHO
Ricisan
JMHO
Ricisan
