Electric Radiator Fan Conversion
http://cgi.ebay.com/ebaymotors/16-El...spagenameZWDVW
Thanks for the help.
I went with a single fan instead of duals so that some of the radiator was not blocked by the electric fan shroud to get some air flowing through the radiator without the fan running. The fan usually runs only when I'm stopped.
)I have a 2350 and it is louder thean the SC that I paid big bucks to hear whine......
That's why you keep your foot in the throttle and you won't hear the fan. Trust me.
That's very easy and cheap to do. A CS130 will bolt right in and give you 100+ amps at idle. A CS144 will fit if you move the upper bracket down an inch.
The wiring is easy, with a plug from Autozone, $4, you can convert the two wire SI plug to the CS plug for the new CS alternator. Easy and cheap.
That's very true...surface area, CFM, shrouding, and avoiding air leaking above or beside the radiator will get you a low operating temp.
I think I'm going to get a new alternator bracket cut with the extra length and the slighly larger adjustment slot. The way I have it tinkered together right now seems to work, though.
I cut mine down a lot, but I also installed a case with 2 and 6 clocking. A 12 and 6 clocking would work perfectly I think, and maybe the lower arm wouldn't have to be lowered.
At Autozone, they have the plug, but I didn't ask. I just looked, and found the CS plug.
I pulled it, put in dual spals, and have ABSOLUTLEY NO cooling problems since. With AC on, or off I run at 180-185 all day long.
I asked the SPAL vendor about the CFM ratings because the Zirgo has such a high rating. I was told that they are comparing apples to oranges: The Zirgo rating is for the fan with nothing to block the air...like a radiator or shroud.
The Spal rating is installed, on a radiator. That is why the Spal rating is lower CFM than the Zirgo.Dunno how true ANY of that is, but it sounded like comparing Gross HP rating on an engine to NET horsepower. Made sense at the time.
For whatever the reason, my dual spals keep my stroker cool as it needs to be. And I too, have a 16" Zirgo for sale.
