Help! Need diff re-assembly help.
I made a technical error by disassembling my differential without first recording the turning torque at the pinion shaft as stated in both of the shop manuals that I have. Now I am re-assembling and need to recover from my error. The GM manual says to tighten the pinion nut until the turning torque is the same as it was after installation of a new oil seal. The Haynes manual says tighten until it exceeds the original torque value by 1 to 5 ft-lbs. I’m not very concerned about this minor difference, but I have no idea what torque value I should seek. The gears and bearings have not been touched on my 56,000 mile ’71 LT-1. I just did new oils seals all around. Can anyone out there give me a reasonable torque value that I should achieve?
the above being said for no other reason than to just give you kind of an idea of what you are trying to replicate.
i have replaced lots o pinion seals without any trouble by simply putting some locktite on the pinion nut, then tighten the nut until there is no endplay. then, i tighten the nut on down against the crush sleeve to about the point that some pre load is there, and there is enough tension against the sleeve to keep the nut from backing off.
some people like to stake the nut on some differentials to ensure it wont come loose. myself, i dont and wouldnt recommend it.
by rear end rebuilders law, once a pinion nut has been loosend, or if a pinion is over tightend, you have to replace the crush sleeve since the tension can not be regained at the same rate and in the same spot. but, i havent had any probs, although i do see their point.
i have read that it take between 300 and 400 ft/lbs of torque to crush a sleeve. seems about right. so if you are doing this job with hand tools i do not for see you gettin it too tight. with out an impact and/or a way to hold the pinion from turning i would think it would be un do able. so, unless you really get outta hand, or you are from the planet Krypton, too tight shouldnt be a problem.
i guess to simply answer your question, which was my original intention until i started typing and it got outta hand......... throw on a little thread locker for insurance, then tighten it till your against the crush sleeve, then tighten it some more.... till it feels right..... and call it good.
http://forums.corvetteforum.com/show....php?t=1576946
