350 Waterpump Leak Question
Old Dec 20, 2006 | 08:57 PM
spedaleden's Avatar
spedaleden
Default 350 Waterpump Leak Question
Guys,
I get 3 teaspoons of antifreeze on the floor right underneath the hormonic balancer. I can not find where it's coming from. I thought it was the heater hose outlet on th pump, nope. It not leaking at the block or the pump.
It happens when the car is shut off and left overnight. I tried pressure testing it and I get no drips.
I know some of you will read this and think I'm crasy about a teaspoon of antifreeze but it is driving me crasy that I don't know were it coming from.
Old Dec 20, 2006 | 09:59 PM
Ironcross's Avatar
Ironcross
It could be from behind the water pump pulley. That would mean the water pump is going bad and naturally need replacement.
Old Dec 20, 2006 | 10:00 PM
Big2Bird's Avatar
Big2Bird
Old Dec 20, 2006 | 10:28 PM
spedaleden's Avatar
spedaleden
I will check that out
Old Dec 21, 2006 | 01:15 PM
SanDiegoPaul's Avatar
SanDiegoPaul
From: San Diego - Deep Within The State of CONFUSION!
Yep. Grab the fan and see if you can wobble the pulley on the pump. If it rocks at all, there's no question. If there is a fan clutch between the pulley and the fan, be sure any rocking you see when you tug on the fan, is not coming from the fan clutch; it's easy to make that mistake.
But as said before, the chances are that you will see a trickle from the weep hole under the bottom of the pump shaft.
Old Dec 21, 2006 | 02:26 PM
jdurhan's Avatar
jdurhan
Water pump shot
Old Dec 21, 2006 | 02:28 PM
spedaleden's Avatar
spedaleden
The pump is only 1 year old and i bought new not rebuilt.. The one thing I love about this car is I have to do everythnig twice on it.
Old Dec 21, 2006 | 03:14 PM
Jud Chapin's Avatar
Jud Chapin
St. Jude 15 Year Donor
St. Jude Donor '11 thru '25
I always try to stay with OEM parts...in this case that would be Delco. Over the years, I found that after market stuff just doesn't last like the originals. Just my 2 cents.
Old Dec 21, 2006 | 08:09 PM
sly vette's Avatar
sly vette
Yup, Weep hole.
Old Dec 21, 2006 | 09:15 PM
genuine1980's Avatar
genuine1980
Correct me if I'm wrong, as I have been MANY times.
He said he gets the teaspoon when the car sits overnight. Weep hole usually only leaks when the cat is running.
I had the same thing with my cat and I thought it was the weep hole... it pressure tested OK. But what I found was that it was a slow leak from the water pump gasket. It would trickle down then engine slowly and I woulnt be able to see where it was comming from. I would get the same teaspoon under my car overnight. I finally pulled the pump to find the gasket was the culprit.
So I would reccoment changing those gaskets as a cheap fix/check, before spending the money on a new pump.
Make sure those hoses are OK too.
Old Dec 21, 2006 | 09:42 PM
rihwoods's Avatar
rihwoods
Tend to agree with that..when the shaft seal goes,you get much more than a couple tea spoons on the floor....
Old Dec 21, 2006 | 11:01 PM
spedaleden's Avatar
spedaleden
shaft is ok and not leaking from weep hole for what I can see. I think there is a crack in the casting. Would the pump leak once it cools or would it leak like a siv when hot?
Old Dec 21, 2006 | 11:55 PM
marshrat99's Avatar
marshrat99
It will leak more when the engine is off than when the engine is running since the coolant is circulating when the engine is turning the pump. You'll have more pressure on the coolant immediately after the engne is turned off and the heat builds into the coolant. My 3 suspions for your leak in order are (1) waer pump as the others have suggested (2) hose near the pump or (3) a remote chance that you have a cracked block or head...very remote IMO. I'd ditch the pump and hoses and be done with it. Again IMO
Old Dec 22, 2006 | 01:10 PM
jlaw68's Avatar
jlaw68
bearing are going bad in the water pump neck. make sure when you get a replacement that its for a vette or you want be able to see the timing tab under the water pump. vette water pump sits a little taller that a standard chevy water pump.
Old Dec 22, 2006 | 01:32 PM
rihwoods's Avatar
rihwoods
Wipe everything down...pump,hose conections etc..start engine and warm it up till thermostat opens......then shut engine down and check hose connections with your hand...if your upper rad hose connection is weeping,coolant runs down on a-arm...if upper hose leaks at thermostat housing,it can run down below pump and/or puddle on intake...it could be lower hose connection to pump or heater hose connections to intake/pump........also,you can jack front end up,and observe from underneath...check freeze plugs on either side of pump on block just in case..
Rich
Old Dec 22, 2006 | 03:45 PM
spedaleden's Avatar
spedaleden
Rich
I told the wife, I setting up the small TV in the garage and sleeping underneath the car tonight and watch for green. She told me Santa is NOT bringing me any more money for that car.
I have looked for leaks, motor only has 2500 miles on it. you can eat off of it. I don't see any drip marks. I think i'm just going to put a new pump on it. Oh what the heck already got 40K in it. What $100 more
To 350 Waterpump Leak Question
