mph rpm ?
Old Dec 22, 2006 | 11:04 AM
dmaaero's Avatar
dmaaero
Default mph rpm ?
if i'm turning 2350 at 55 mph what kinda gears do you think i have?
Old Dec 22, 2006 | 11:07 AM
Big2Bird's Avatar
Big2Bird
What is the diameter of your tire?
Wrecked82's Avatar
Wrecked82
My speedo says I an going about 95 at about 2400 rpm, but that is because I changed from a 2.89 to a 3.55 and have not changed speedo gearing yet!
When I had the 2.89, 55 would have been about 1700 rpm.
Old Dec 22, 2006 | 11:19 AM
dmaaero's Avatar
dmaaero
p255/60r15 26 inch diameter
Old Dec 22, 2006 | 11:20 AM
Big2Bird's Avatar
Big2Bird
IF your tach and speedo gears are correct, you have 3.55.
Old Dec 22, 2006 | 11:24 AM
dmaaero's Avatar
dmaaero
thanks bigbird
Old Dec 22, 2006 | 12:07 PM
JIMS1970VETTE's Avatar
JIMS1970VETTE
What is the formula to fiqure it out?
Old Dec 22, 2006 | 12:40 PM
Big2Bird's Avatar
Big2Bird
RPM=MPH x ratio x 336/Tire diameter
For those who are mathmatically challanged, go to unitrax.com, and use their computer.(Like I do)
Old Dec 22, 2006 | 01:00 PM
Glensgages's Avatar
Glensgages
This is the formula I have used for many years:
GEAR RATIO = RPM x .9 (if using a non-locking torque converter ) x .006 ( a factor, incorporating pi ) x 1/2 TH (tire-height ) divided by MPH x OD/R (over-drive ratio, if any ).
If your 255/60R15s are 26" tall (mine are slightly-taller than 27" ????? ), I would estimate your rear-gear ratio at close to 3.00:1, 'assuming' you are running a THM350/400 w/o a locking converter.
Old Dec 22, 2006 | 01:57 PM
redwingvette's Avatar
redwingvette
try this site:
http://richmondgear.com/101032.html
To mph rpm ?
