Automatic door locks???
Old Dec 23, 2006 | 03:58 PM
rudolph schenker's Avatar
rudolph schenker
Default Automatic door locks???
I have an 82, and in the process of removing the door panels and checking the locks I must have accidently blown a fuse. Not a big deal, right?? However, I can't find the correct fuse!! I have checked them all, and they seem intact. Although, Door locks still won't work. Any ideas???
Old Dec 23, 2006 | 05:09 PM
...Roger...'s Avatar
...Roger...
The fuse is the ctsy,clk fuse 20 amp----did you move your ground ?its in the rt door
Old Dec 23, 2006 | 05:21 PM
spedaleden's Avatar
spedaleden
Take a test light and test the fuses in the fuse box. Check both sides of the fuse with the ignition on, so they all have power.
Old Dec 23, 2006 | 05:43 PM
...Roger...
On the pass side is the ground for both sides-2 black wires that are screwed to the metal door.If you need the wire colors and positions for the switch plug here they are.
For 1982
Drivers side ........ Pass side
A-orange .... A-orange
B-black ...
C-gray ... . C-lt.blue
D-tan .. ... D-black
E-lt.blue ... .. B&E-double black screws down to door
Old Dec 23, 2006 | 09:47 PM
BDCMPNY's Avatar
BDCMPNY
Is your clock in the dash working? If yes your fuse is okay. If not replace the courtesy fuse. Just a good place to start. BDCMPNY
Old Dec 23, 2006 | 10:50 PM
rudolph schenker
I checked the fuse again. It didn't appear burned, yet I replaced anyway. Well that did the trick. Both locks work!!! Thanks for the help!!
Old Dec 24, 2006 | 12:26 AM
...Roger...
To Automatic door locks???
