69 Battery Box
Old Dec 23, 2006 | 10:05 PM
coinwasher's Avatar
coinwasher
Default 69 Battery Box
Still looking for a battery box is someone is cutting one up. Mine had a half shaft blow through it in those abuse years. The car I am working on is a 69.
Old Dec 23, 2006 | 10:33 PM
Durango_Boy's Avatar
Durango_Boy
Does it have to be a stock correct box? You could make your own very easily out of sheet steel or sheet aluminum, or even make your own out of fiberglass, using the other side as a template...and glassing it in yourself.
Old Dec 23, 2006 | 11:57 PM
Jud Chapin's Avatar
Jud Chapin
St. Jude 15 Year Donor
St. Jude Donor '11 thru '25
How about a pic of what is left of the box. That would help in determining what is needed to rebuild it.
Old Dec 24, 2006 | 01:58 AM
68 NJConv 454's Avatar
68 NJConv 454
There were a few guys on here who had 68 batter boxes when i was repairing mine. Not too expensive but the shipping from texas made me rethink the deal. I ended up reglassing my own out of fibgerglass matt and tinfoil. The tinfoil gave me some form which I glassed over and then just pealed the tinfoil off. Looks great but then again not absolutely perfect but i'm not goin ncrs.
Old Dec 24, 2006 | 05:59 PM
Durango_Boy
You got any pictures of that work? I'm really curious in case I ever have to do that.
Old Dec 25, 2006 | 10:27 AM
Red 69's Avatar
Red 69
The fiberglass resin will release from plastic sheet. Use plywood or like material for a form with heavy plastic sheet sandwiched between. Lay -up your fiberglass over it and peel the plastic off after it becomes hard. I'd work the inside with the form outside for a better cosmetic finish. Lay-up several layers of fiberglass over another plastic sheet while working on your bench. Pick up the plastic and transfer the resin soaked fiberglass directly to the work surface. Roll it down to remove air pockets and pull off the plastic sheet after it gets hard. Use heavy plastic and not the thin stuff. The thin plastic can tear in spots when removing. It is easily removed with a grinder, I just think the heavy material works better. Wear disposable latex gloves and the job isn't so messy. Acetone will remove the resin from places you don't want it. Mark the perimeter of each piece of fiberglasss mat/cloth with a Sharpie marker to easily monitor your overlap. For strength in a battery box you might like to use mat on the finish sides with a layer of cloth in the middle. Don't overdo the resin, the strength is in the material.
Old Dec 25, 2006 | 11:14 AM
GUSTO14's Avatar
GUSTO14
Dan...
Send an email to Todd at jacksonauto@earthlink.net
I know he has a couple of early C3's he uses for parts. You can also call him at (910) 298-4722 He's located in eastern NC.
Good luck... GUSTO
Old Dec 26, 2006 | 12:23 PM
Durango_Boy
Originally Posted by GUSTO14
Dan...
Good luck... GUSTO
What years do his parts cars span? Also, there is a place near St. Louis, MO, that Sam knows about, and they have a lot of C3s for parts too.
Old Dec 26, 2006 | 01:16 PM
GUSTO14's Avatar
GUSTO14
Matt...
The best thing to do is shoot him an email and ask him. I believe one is a chrome bumper car and there are a couple of rubber bumper cars. They each have had various pieces removed for restorations they have done in the past and are currently working on.
GUSTO
Old Dec 26, 2006 | 01:17 PM
Durango_Boy
Matt...
GUSTO
Thanks, and I would email him if I were looking for something...I just thought I'd ask in case you knew what years he had. No big deal...he can email if he's interested.
Old Dec 26, 2006 | 10:00 PM
coinwasher's Avatar
coinwasher
Guys, I was offline today but thanks so much for all of the support on this. I got an email from a guy who is sending me one for fifty bucks that came out of a 69. I will splice it in and glass it really well (dropping a battery going down the interstate would not be cool).
My chassis is complete and now I plan to have the body ready to go back on the frame in about four weeks. The tough part is going to be covering the frame (powdercoated) so that the body shop does not get overspray all over everything.
Old Dec 29, 2006 | 12:31 PM
Durango_Boy
A few rolls of tape-off paper, and many, many...many rolls of painter's masking tape.
Old Dec 30, 2006 | 09:03 PM
68 NJConv 454
Broken....bubba did it
After reglassing.... (notice the tin-foil. I had to glass the bottom on the workbench ontop of the tin-foil and leave nonresin'd fiberglass off the sides so once the bottom dried I could resin the overhang to the sides of the battery box. Can't fiberglass upside down...ask me how I know! stupid gravity then peal the tinfoil right off..soo smooth)
After sound and heat insulation spray....
Old Dec 30, 2006 | 09:05 PM
Durango_Boy
Very sweet. Good job bud.
Old Dec 31, 2006 | 01:06 AM
Jud Chapin's Avatar
Jud Chapin
Looking good. You da man!
Old Dec 31, 2006 | 08:54 AM
3joh's Avatar
3joh
The body shop will be able to cover the underneath of the car along with all of the other openings to eliminate overspray. My engine comp and chassis were complete when I sent it to paint and the body shop kept it covered. They said it was harder to tape off the car than actually paint it since I had everything detailed already. I think the restoration needs to be done in that order to eliminate overspray and/or damage to the new body paint.
Good fiberglass work 68 NJ!
Old Dec 31, 2006 | 10:26 AM
Durango_Boy
3joh - Nice color man. I like it a lot...deep and rich.
To 69 Battery Box
Old Dec 31, 2006 | 01:46 PM
coinwasher's Avatar
coinwasher
I thought about painting the body before I put it back on but there are so many opportunities to chip it up during the reinstall. Also, I want to drive it 200 miles after the install in primer (such a redneck) to allow for any stress cracks. Man your paint color is awesum! What color is that and do you have any pictures of the finished car?
Old Jan 2, 2007 | 09:46 AM
68 NJConv 454
Love that color
Old Jan 3, 2007 | 06:50 PM
Durango_Boy
Love that color
Great shine under those lights too. Very good finish.
