L82 engine
Old Dec 26, 2006 | 06:04 AM
1ronaldo's Avatar
1ronaldo
6th Gear
Default L82 engine
Hello Vette friends! Since 3 years I have my 1979 car with L82 under the hood. It took me some 2 years to restore the Vette and I am proud of her. As a Dutch member since last week of this great site I have several guestions. One is: Which engine pieces make the difference with the standard L48 engine? Furthermore which main other subjects and settings give their contribution to the better performance? In literature I only found out that compression ratio is 8.9 instead of 8.2.
thanks in advance,
Ron
Old Dec 26, 2006 | 07:43 AM
Ganey's Avatar
Ganey
The primary parts for the better power of L-82 are performance cam & heads w/ larger valves & higher compression pistons.
Old Dec 26, 2006 | 08:08 AM
jotto's Avatar
jotto
Does the L82 have a forged crank or other forged parts?
Old Dec 26, 2006 | 08:18 AM
Ganey's Avatar
Ganey
Yes.
Old Dec 26, 2006 | 10:55 AM
79-L-82's Avatar
79-L-82
Intake is aluminum as well.
Forged pistons, larger valves and different heads/cam as mentioned above.
Old Dec 26, 2006 | 01:55 PM
Duke94's Avatar
Duke94
This thread tells all.
http://forums.corvetteforum.com/show...hlight=L82+L48
Old Dec 27, 2006 | 04:38 AM
1ronaldo's Avatar
1ronaldo
6th Gear
tnxs for the info. helps a lot to understand.
Old Dec 27, 2006 | 04:54 AM
1ronaldo's Avatar
1ronaldo
6th Gear
Default L82
Thanks all for the information and threads showing all the information I needed to make a clear picture
To L82 engine
