Chassis dyno run ?
Old Dec 26, 2006 | 10:35 AM
Gordonm's Avatar
Gordonm
Default Chassis dyno run ?
73jst4fun and I have an appointment this Thursday for some dyno runs. Besides checking everything, running through the valve clearance, making sure the timing and everything is set what else do we need or should do. I have a complete set of jets for the carb, timing lights, misc. tools is there anything else we need. The dyno has an AF gauge so I'll leave my LM1 at home. Any dyno veterans with any words of wisdom?
Old Dec 26, 2006 | 10:40 AM
SanDiegoPaul's Avatar
SanDiegoPaul
From: San Diego - Deep Within The State of CONFUSION!
ANY dyno shop should have the ability to set your timing and fuel mixture! All *-YOU-* need to do is make sure it has at least a half tank of gas and clean filters - air and fuel.
Old Dec 26, 2006 | 10:52 AM
ML67's Avatar
ML67
You may want to throw a fresh set of plugs in there depending on how old your current plugs are. Bring a notepad so you can record your changes. Don't forget carb gaskets. If you have 2 O2 bungs, you may want to bring your LM1 to compare to the shop's AF meter. Cameras and videos are nice as well!
Have fun and good luck.
Mark
Old Dec 26, 2006 | 11:22 AM
Gordonm's Avatar
Gordonm
Mark
Carb gaskets! Got some extras. I'll put them in the box also.
Old Dec 26, 2006 | 12:20 PM
PRNDL's Avatar
PRNDL
where are you going?
Old Dec 26, 2006 | 12:27 PM
Gordonm's Avatar
Gordonm
Its a secret!
Somewhere in Lakewood. Right off Rt 70 in the industrial park off Airport Rd. Don't know the name, 73jst4fun set it up.
Old Dec 26, 2006 | 04:22 PM
7t2vette's Avatar
7t2vette
The ORIGINAL and bestest
Toronto Events Coordinator
Little cup to catch the fuel when you crack open the bowls to change the jets.
Old Dec 26, 2006 | 04:39 PM
Gordonm's Avatar
Gordonm
Already in the box. I have a heavily modified 7UP can that serves duty for a fuel catcher.
Old Dec 26, 2006 | 05:07 PM
Vette80regon's Avatar
Vette80regon
yep...turn off the a/c
better yet, disconnect it
personal experience
Old Dec 26, 2006 | 05:21 PM
Gordonm's Avatar
Gordonm
personal experience
AC what the he$$ is that. Never had it.
73jst4fun diconnected his system this winter. Uncluttered his engine compartment plus lost a lot of weight.
Old Dec 26, 2006 | 07:59 PM
73jst4fun's Avatar
73jst4fun
Lost alot of weight in the front with that change....just bring your $$$$$ This should be fun on Thursday.... I told the guy we had no electronics/computers to deal with and he "praised the Lord"...
Old Dec 26, 2006 | 10:14 PM
ZL1powr's Avatar
ZL1powr
This is probably obvious but make sure your throtle blades are opening all the way when the accelerator is on the floor so you don't waste runs like I did trying to figure out why power was way off.
Old Dec 26, 2006 | 10:58 PM
MrForce's Avatar
MrForce
St. Jude Donor '11, '14
Don't forget. You will be "driving" over 120 mph. Air the tires, tighten the lugnuts, inspect u-joints, coolant and hose connections, etc. Any thing you would do before an autocross, 1/4 mile pass, or long road trip. Also make sure your dyno guy knows how to strap down and IRS equipped car.
Good luck and have fun.
Old Dec 26, 2006 | 11:12 PM
spedaleden's Avatar
spedaleden
Take pics or even better video
Old Dec 27, 2006 | 09:04 AM
Gordonm's Avatar
Gordonm
Did this after the last drag strip run and found out they were not opening all the way. This has been corrected now.
Probably closer to 150 mph. I'll probably go to 7000 rpm. I'll make sure everything is tight and up to pressure.
Going to bring my camera. It is capable of short video clips also. Looks like my son is coming with me so he can take the video or pics.
I'll go over the car today to make sure nothing obvious will happen. You know Murphys law though
Old Dec 27, 2006 | 11:30 AM
gkull's Avatar
gkull
tell me about your ignition/wires/plugs.
Old Dec 27, 2006 | 12:14 PM
Gordonm's Avatar
Gordonm
I am running the stock dist that has been recurved. Right now I have 20 initial with 36 total and the vacuum advance disconnected. The HD points fire a Crane HI6 box with a MSD coil. The plug wires are Moroso Blue Max The plugs are new within the last 300 miles gapped to .040. They are AC plugs.
To Chassis dyno run ?
Old Dec 27, 2006 | 12:16 PM
SanDiegoPaul
I would run the plugs at .045" though.
jotto's Avatar
jotto
VIDEO!!!!!!!!!!!!!! pretty please!!! we want to see the runs and know what adjustments you make between each!
Good luck hope you get the figures you are hoping for.
Old Dec 27, 2006 | 01:48 PM
gkull's Avatar
gkull
I would even go .050. I'm also a firm believer in 4 tip plugs like the Bosche Plat 4P.
Depending on your chamber type I would try some other max timing settings in 2 degree increments.
The local shop here that I have dealt with doesn't allow over 120 mph and prefer lower. I don't know the correction factor for using other than a 1:1 gear. You might ask about running in 2nd or 3rd
