Trailing Arm Bushing's
Old Dec 26, 2006 | 11:08 PM
Racer11's Avatar
Racer11
Default Trailing Arm Bushing's
I am re building the rear undercarriage on my 76. I discovered that I need to replace the trailing arms. The arms with the rubber stock bushings are cheaper than the Poly bushings.
Is the extra expense a big benefit to use the Poly's......I dont do any racing or auto-x stuff. But sometimes I kick it up a bit on the straight segments of a road and some curves......
The car never sits outside for any rubber decay........
Old Dec 26, 2006 | 11:12 PM
big_G's Avatar
big_G
Rubber is usually good for 20 years or more. Good enough for me.
Old Dec 27, 2006 | 10:47 AM
GTR1999's Avatar
GTR1999
I agree use the rubber.
Old Dec 27, 2006 | 01:45 PM
BerniesVette's Avatar
BerniesVette
The trailing arm bushings should be rubber instead of poly. Ask Van Steel and he will tell you the same thing.
Bernie
Old Dec 27, 2006 | 04:19 PM
I'm Batman's Avatar
I'm Batman
St. Jude Donor '07
I despise rubber bushings...everything in my suspension is going to be poly except for the T/A bushings...those are going to be solid steel spherical bearings.
Old Dec 27, 2006 | 04:34 PM
rihwoods's Avatar
rihwoods
Just replaced mine in the 78 after 28 years/130,000 miles...stayed with rubber....
Old Dec 27, 2006 | 11:06 PM
Racer11's Avatar
Racer11
Thanks guys
Rubber it will be on the arms,,,,will be ordering soon
To Trailing Arm Bushing's
