Three years ago, I had lowered my front end by cutting the stock springs about a coil and a half. The rear, I had installed 10" spring bolts. I have driven the car approx 80 miles since then (to/from a couple of shows).
I noticed that the front has finally sagged and the rear had always seemed 'bouncy' on th freeway.
Well my car turns 25 in January and I want to get the car all registered and 'drivable'. However, I would like to maintain its low stance.
I would like to get some advice on how to 'properly' lower the front and rear end. Are 'correct' lower springs the only way to go on the front? How about the rear? How do I determine if my rear leaf spring is shot?
Is there like coil over conversion kit where I could fine tune the ride height?
I know there are some suspension gurus here who will eventually respond for you. I'm not one of them, but can advise you to call VB&P as they are helpfull, a suppoting vendor here on the forum and will come highly recommended by many forum members here. Good luck with it!
Talking to VB&P is good advise. You can get coil over shocks for the front & rear, or you can get an air system that's race proven for the same money. G/L
They have a kit with transverse front and rear springs that are fully adjustable after installation. You will have the proper spring, but can lower it as far as you like.
