Budman78's Poor mans serpentine
Old Dec 28, 2006 | 08:44 PM
77 vette's Avatar
77 vette
Default Budman78's Poor mans serpentine
Kool info but I can't find this anywhere, anyone have a link. Thanks
Old Dec 28, 2006 | 09:16 PM
Durango_Boy's Avatar
Durango_Boy
A link to what? I'm confused.
Old Dec 28, 2006 | 09:17 PM
SIXFOOTER's Avatar
SIXFOOTER
< is a poor guy and I got mine off a 79 surbaban in a wrecking yard in texas for $75
Old Dec 28, 2006 | 09:35 PM
77 vette's Avatar
77 vette
I saved the web site to my desk top a while back (along with hundreds of others) and must have cleaned it off. I thought he deleted a tenchener and used his alternator to supply force, I think he also had a small A/C delete and used a shorter belt. I'ts kinda a cool small/compact set up.
Old Dec 28, 2006 | 09:39 PM
Durango_Boy
Does it look like this? I don't have the power steering pulley on or the belt in this pic, but it's a '92 Camaro serp system for cheap on Ebay, with an A/C and smog delete pulley. I can get your the part numbers for those pulleys if you ever get that serious about it.
Old Dec 28, 2006 | 09:46 PM
77 vette's Avatar
77 vette
I haven't seen his pictures and write on it for a while but It looked more condensed that yours, I think he maybe had a few less pulleys.
Old Dec 28, 2006 | 09:56 PM
Budman68's Avatar
Budman68
Cruise-In VII Veteran
St. Jude Donor '07
I think the corvettefaq lost it somewhere down the road. There is still some pics in "my corvette photos" but no tech info.
If I remember correctly you can use the following parts.
84 Vette A/C compressor with bracket, remove tensioner
85-87 Vette Water pump, save bolts. They are expensive and hard to get.
88 up Vette Power Steering pump and bracket, you will some AN adapter fittings or just peice the old and new hoses together
90 Chevy truck alt. 100+ amp without the smog pump bracket or delete.
I used a heim joints and custom tension bracket from street and performance.
Forgot the belt #.
The whole package will spin to whatever rpm range without an issue. No shimming or spacers needed.
Hope this helps.
Buddy
Old Dec 28, 2006 | 10:01 PM
Durango_Boy
There is a version that's a bit tighter, where the A/C and tensioner are pulled in towards the center, I think it's from the truck motors and V6 motors. Problem is that you'll have a hood clearance with any of them unless you get an aftermarket hood.
Also, they all have the same pulleys. Now, you can remove the smog pulley all together, and run a shorter belt...but I feel the belt will vibrate too much if that smog delete isn't there.
Old Dec 28, 2006 | 10:26 PM
77 vette's Avatar
77 vette
Forgot the belt #.
Hope this helps.
Buddy
"Rats". Your right I just checked faq and it's not there. Thanks for the information and head start, I'll have to do a little digging but I think I can figure this out.
Old Dec 28, 2006 | 11:30 PM
Durango_Boy
What is it you want to know. There are only a few versions, and one or more of us have them. We can probably tell you what you're looking for.
Old Dec 29, 2006 | 09:30 AM
Budman68's Avatar
Budman68
St. Jude Donor '07
I think he wants it to look more like stock, which is what this version looks like. No big alum. brackets. Here's a shot with my old TPI motor.
Old Dec 29, 2006 | 10:21 AM
Durango_Boy
How did you attach the accessories if there are no aluminum brackets? They are the serp system.
Old Dec 29, 2006 | 12:31 PM
77 vette's Avatar
77 vette
"YES". That's what I want. Didn't you also have a small A/C delete pulley mounted lower on the heads? Also didn't you use the alternator for belt tension? Thanks Budman you ROCK!
Old Dec 29, 2006 | 05:52 PM
Budman68's Avatar
Budman68
St. Jude Donor '07
The 84 - 85 A/C vette bracket has a tensioner on it. I ended up cutting it off, because it is not needed. You can buy the smog pump delete bracket and pulley, but it is not needed. You just mount the alternator and use a 2 heim joints and peice of metal tubing to push the alt. out for tension.
The only thing I didn't like about the layout was the length of the belt from the alt. to a/c up on top. It works fine, but looks long to me.
Old Dec 29, 2006 | 05:55 PM
Budman68's Avatar
Budman68
St. Jude Donor '07
Old Dec 29, 2006 | 08:33 PM
Eddie 70's Avatar
Eddie 70
Ci 6, 8 & 10 Veteran
St. Jude Donor '05-'06-'07-'08-'09-'10-'11-'12-'13-'14-'15
Oooooooh. I like this setup. Looks nice and clean. Good work. I can't remember, did you use this setup on the LS? Probably does not bolt up to the LS. Just curious.
Old Dec 29, 2006 | 10:35 PM
Budman68's Avatar
Budman68
St. Jude Donor '07
Nope, this was on the old motor. The LS has the F body brackets.
To Budman78's Poor mans serpentine
Old Dec 30, 2006 | 01:32 PM
Durango_Boy
That is a very long span across the top. Do you like it that way?
Old Dec 30, 2006 | 03:36 PM
Budman68's Avatar
Budman68
St. Jude Donor '07
Actually, never had a problem with it. It didn't flap or anything, just did it's job.
Old Dec 30, 2006 | 04:07 PM
Durango_Boy
Do you have a better picture of the alternator tensioner? Also, what power steering pulley did you use. Looks like it would have to be a smooth since the back of the belt rides around it.
