More tubular A-arm pics
Is that going to be strong enough? In my opinion the upper and lower front cross shafts are the most important pieces of the suspension and thus require a lot of strength and fatigue resistance. Evey time you hit a pothole these pieces take a pounding placing many tons of shear impact loading on them.
Seems like i remember someone talking about aluminum cross shafts. That seems crazy to me.
316 Stainless....
There you go again Turtle... Now I need to build an ANSYS model and run a couple million cycles to see what happens...
You sure know how to spoil a party....
are you serious or just making fun of me? I'd be interested in your results. I have aluminum caliper brackets i'm worried about.
This kind of in depth analysis is what i envisioned in the tech section when we started it.
Doing a FEA isn't that hard however those should be strong enough, the upper arm doesn't nearly see the loads that the lower one does.
I was poking some fun kinda...
I was gonna make them from 7075-T651 its about as strong as 316 stainless but I felt like the stainless would fail in a more graceful manner.
I have the geometry of the part already, We know the material properties, and I'd bet we could get some good estimates of the loads on the members with a little work.
That said I had a 6' long 1" bar setting there and it will work.
Static loads are pretty easy.... It's dynamics and fatigue that'll get ya. I switched from Engineering to Mathematics and now I'm working on Comp Sci.
Most of us see bent lower cross shafts when we rebuild the bushings and that's a pretty stout piece of steel so this is what worries me.
I was able to beat it straight with just a few blows from a hand sledge so maybe the stock cross shaft is not even that strong.
You gonna come run with me when you finally get that thing together? There has been a small resurgence of C3s in the COM club. I roped Restorod79 into the game although it looks like Scooter70 is retired.
