Hood Alignment Problems
Old Dec 30, 2006 | 12:11 AM
76 VETTE's Avatar
76 VETTE
Default Hood Alignment Problems
Hope That Somebody Can Help Me With This. When The Hood On My 76 Is On And Raised It Seems To Hit The Vacumn Light Canisters And Pulls The Hoses Off. Is There Any Way To Move Them Down Or Forward? Thanx Guys!
Old Dec 30, 2006 | 08:50 AM
andylmusic76's Avatar
andylmusic76
are you talking about aligning so the gap is the same width all around the hood?
Old Dec 30, 2006 | 09:04 AM
Jud Chapin's Avatar
Jud Chapin
St. Jude 15 Year Donor
St. Jude Donor '11 thru '25
I just looked at my '76 (all original) and the canister hoses are an inch or so away from the hood when it is open. If your hood is properly aligned, obviously the problem would seem to involve the position of the canisters. Is this something that just started?
Old Dec 30, 2006 | 10:27 AM
Artsvette73's Avatar
Artsvette73
There is a right and left canister may be they are reversed
Old Dec 30, 2006 | 10:43 AM
Duke94's Avatar
Duke94
The 90 degree bent tubes coming out of the actuators should point toward the center of the car. Also, you may need to tie wrap the hoses back so they are further away from the hood.
Old Dec 30, 2006 | 01:41 PM
76 VETTE's Avatar
76 VETTE
i just looked at my 76 and the actuators are both facing out. i will try to reverse them to face in,the hood is aligned and the front edge hits right at the hose andinlet. looks like you guys have solved the problem. thanx guys!
Old Dec 30, 2006 | 02:19 PM
Jud Chapin's Avatar
Jud Chapin
I just looked at my '76 again and the tubing bends outwards. I bought this car new and the actuactors have not been touched. Also, I just checked the '76 assembly manual which shows them pointing outwards. Further, there does not appear to be much, if any, adjustment on them. Checking the clearance between the hood (in open position) and the tubing on my '76, it is very tight to get my finger between the hose and the hood. Perhaps adjusting the hoses would help. Again, you didn't say whether this is a new problem or something that has been with this car since you've owned it.
Old Dec 30, 2006 | 02:43 PM
Duke94's Avatar
Duke94
Odd, both my 71' and 78' point toward the center. It's not clear in the AIM which way they point, but they do call for a right and left actuator.
Old Dec 30, 2006 | 02:56 PM
Jud Chapin's Avatar
Jud Chapin
Here's a couple of pics of the right side of my '76. Keep in mind that I can barely get my pinky finger between the hood and the actuator hose:
Old Dec 30, 2006 | 03:16 PM
Jud Chapin's Avatar
Jud Chapin
Yeah, that is strange, Duke. If we could get a little more info we might be able to resolve this. If this problem just started, that's one thing as something has probably moved. But if it has always been like this since he's had the car, that is another.
Old Dec 30, 2006 | 03:21 PM
76 VETTE's Avatar
76 VETTE
This Has Been A Problem For Some Time. Just Decided To Deal With It.i Thought There Might Be An Adjust Ment In The Canisters. Mine Looks Exactly Like Yours Except The Hood Is Hitting The Hose And Inlet. I Was Hoping That Canisters Were Reversed But Now Wondering If It Is That. Have To Look Again And See If I See Anything Else. Thanks For The Pics And Info.
Old Dec 30, 2006 | 03:28 PM
Jud Chapin's Avatar
Jud Chapin
I believe the actuators are held in place by two studs which are part of the assembly. They go into a bracket that has holes to accept the studs and are held in place by 2 nuts. Perhaps you can get some adjustment out of them to give you just enough room. Otherwise, perhaps your hood is adjusted too far forward. Is it lined up evenly all the way around?
Old Dec 30, 2006 | 10:51 PM
76 VETTE's Avatar
76 VETTE
I Did Notice That The Hood Could Use About 3/16 Shim To Make It More Even With The Fenders. Which I Think Would Give It A Little More Room. I Completely Did A Frame Off Restore On This Car Over The Last 2 Years. I Took It To A Local Carstar To Get A Paint Toch-up Last June. While The Car Was There It got Flooded And Completely Totaled.IGot To Drive It 20 Miles. I Have Just Started To Restore It For The Second Time. This Is Just One Of Many Headaches To Overcome. I Have The Engine Running Good.your Car Looks Great. Nice To Have A Car From Day One To Keep It Just The Way You Like It.THanks Again.
Old Dec 31, 2006 | 12:56 AM
Jud Chapin's Avatar
Jud Chapin
You are welcome. Perhaps getting the hood even all the way around will solve the problem. I hope it does and good luck.
Old Dec 31, 2006 | 11:50 AM
76 VETTE's Avatar
76 VETTE
Looked In My Assembly Manual And They Definatly Show Them Pointing Out. That Kind Of Makes Sense With The Way The Front Of The Hood Is. The V Would Give Them More Clearence. I Will Try To Reverse Them Today .
Old Jan 6, 2007 | 05:40 PM
76 VETTE's Avatar
76 VETTE
Got The Shims Today And Will Try It Tonight.it Looks Like It Will Raise The Hood ,giving The Hoses More Clearance. When I Got It There Were No Shims. The Assembly Manual Shows Them.
Old Jan 6, 2007 | 11:02 PM
76 VETTE's Avatar
76 VETTE
Just A Quick Up Date. Got The Grandkids To Sleep And Snuck Out In The Garage For A Few Minutes To Put The Shims In.i Put Two 1/16 Shims In Each Side And Bingo. No More Hitting The Hoses. About An 1/8 Clearance For The Hoses. Good Enough For Me. Thanks Jud And Duke.also Wondering If Yours Has Shims In Them. Thanx Again.
To Hood Alignment Problems
Old Jan 7, 2007 | 08:31 AM
Jud Chapin's Avatar
Jud Chapin
Mine has 2 shims on the base of the right hinge and none on the left. Glad you got it fixed.
Old Jan 7, 2007 | 08:41 AM
76 VETTE's Avatar
76 VETTE
I Think Somebody Changed The Hood Before I Got The Car And Didn't Put Them Back. Thanks Jud.
Old Jan 7, 2007 | 08:47 AM
Jud Chapin's Avatar
Jud Chapin
Dale, did you swap the canisters or were they in there correct positions?
