Timing Chain help !
Old Dec 31, 2006 | 10:11 PM
big_G's Avatar
big_G
If the distributor has not been removed, do nothing. If it has, install it with rotor to #6 plug post on the dist. if the dots are together. Install dist. rotor to #1 plug post if the cam dot is at 12 o'clock.
Old Dec 31, 2006 | 10:16 PM
luerja's Avatar
luerja
Yes the distributor has been remove (the engine was just rebuilt). So I will install distributor with the rotor facing #6....
Thanks for the help
Jim
Old Jan 1, 2007 | 10:59 AM
Durango_Boy's Avatar
Durango_Boy
When I built this motor I put the pistons to #1 TDC. Then, I lined up the dots at 6 & 12 o'clock. Will I have to redo this?
Old Jan 1, 2007 | 12:23 PM
noonie's Avatar
noonie
The cam sprocket has a hole for the cam locating pin. The sprocket will only fit on the cam in 1 position.
The crank sprocket has the keyway to match the key in the crank. It will only fit in 1 position.
You can match the dots or use the 12 o'clock method.
You can't screw it up.
Since the cam revs at 1/2 crank revolutions, you will find that when the crank dot is at 12 noon the the cam is at 6,
then turn the crank 1 rev to get the crank at 12 noon again and the cam will be at 12 noon also.
It doesn't matter if you turn it clockwise or counterclockwise or whatever, when the crank dot is 12 noon the cam dot can be at 12 or at 6. The realationship of the #1 piston at this stage doesn't matter. It will automatically be correct.
When you install the distributer, is when you worry about the #1 firing position. Just put #1 firing at TDC and all is well automatically.
Turn the crank by hand and watch the dots and it will be easy to see.
BTW
Happy New Year
Old Jan 1, 2007 | 12:27 PM
Durango_Boy
Thanks Noonie. Very good explanation.
Old Jan 1, 2007 | 12:47 PM
noonie's Avatar
noonie
Durango_boy
Hope 2007 will be a good year for your projects
Old Jan 1, 2007 | 12:50 PM
Durango_Boy
Originally Posted by noonie
Durango_boy
Me too. Today's a waste with this hang over...but I'm still out here turning and throwing wrenches.
Yes, I did too much... ...
...but at least I didn't...
