TPI install cost breakdown $$$
Old Dec 30, 2006 | 09:14 PM
DR.Jay's Avatar
DR.Jay
Default TPI install cost breakdown $$$
Well I added up all the reciepts from the install since it is mostly complete, and the system is up, and running. Here is the list of parts by name, with prices to date in US dollars.
'87 chevy Camaro TPI donor car complete FREE
Accel 21# hr injectors: 259.99
18mm non fouler: 4.29
Upper radiator hose '87 Z-28 350ci 15.99
Plenum to intake hose U shaped 9.99
B&W O2 sensor single wire 19.99
B&W knock sensor 350ci 27.99
Felpro TPI intke gasket set 29.99
195* t-stat & gasket 4.78
Aux fuse panel 12.99
VSS 2000 pulse per mile 30.99
Fuel filter 2.69
Fuel pump for '87 vette 49.99
Fuel pump strainer 6.99
Custom burnt prom 65.00
Cone style Air filter to fit MAF sensor 24.99
New heater hoses 13.08
New heater valve 8.99
Misc Parts & supplies aprox cost 50.00
Total cost not including tax or shipping = $643.70
Doing the TPI conversion my self, and being able to sell the rest of the Camaro for parts, to pay for the TPI conversion = Priceless
Dr.Jay
Old Dec 30, 2006 | 09:19 PM
Pusher's Avatar
Pusher
Old Dec 30, 2006 | 09:20 PM
DR.Jay's Avatar
DR.Jay
Even If I were to have bought the intake, ecm, and harness. I would have spent about $1100 which is far less than a "Stealth Ram" from Holly, or An Accel "DFI Pro-Ram"
Old Dec 30, 2006 | 09:24 PM
big_G's Avatar
big_G
Ah yes, but don't compare your TPI to those two...or a TPIS mini-ram. They are worth at least 75 hp at anything >6,000rpm. . Nice job, Jason. The torque the TPI develops down low is neck-snapping.
Old Dec 30, 2006 | 10:20 PM
DR.Jay's Avatar
DR.Jay
I was comparing just the cost. Thanks for the Compliment Gary!!! What do you think about some Edelbrock runners??
When I took it for a spin around the block the other night the pin you to your seat, "neck-snapping" torque was amazing even in the rain (thanks Travis county for the agressive asphault).
I still can not get over the exhuast note. It is a sharper more piercing tone compared to the lower pitched rumble from when I had the carb on it.
Any eta on getting your engine back yet???
Old Dec 30, 2006 | 10:37 PM
big_G's Avatar
big_G
I prefer the large-tube runners from Arizona Speed and Marine, but the bottle-neck is the runner...so any improvement you do will help. As far as the ETA on the engine...well.... machine shops have 2 speeds....slow and stop. As long as the work is quality, I'll deal with slow.
Old Dec 30, 2006 | 10:44 PM
Artsvette73's Avatar
Artsvette73
I have been following this post. Great Job.. I have a Holley Stealth Ram sitting up in my closet. I have a speed density C4 harness but the wiring I have't figured out yet. It is destined to go in my 73 383. I guess I will really have to look it to one of those neck braces. Again Job well done.
Old Dec 30, 2006 | 11:14 PM
DR.Jay's Avatar
DR.Jay
First of all thanks for the compliment.
I was worried about the same thing, but with the help from the forum members, by them posting advice, and links to useful websites I was able to accomplish the install. Ask alot of questions, do alot of reading (wire schematics for the car your harness came from + & - one year for assembly line changes), and make notes about what you see while reading the schematic with the harness spread out in front of you, so you are familiar with it.
Try to have all the parts you will need gathered before you start. thats why you see MISC $50 at the end of my list. It is for the little things that if I didn't plan ahead could have put a damper on the project.
By little things I mean; Hose clamps, electrical tape, solder, heat shrink tube, vacume hose (numerous sizes) Fuel injection hose, wire end connectors, vacume port caps, etc. You can't think of everything, but one unexpected trip to the parts store is better than 10.
Thanks again for the compliment
DR.Jay
Old Jan 1, 2007 | 10:10 AM
DR.Jay's Avatar
DR.Jay
Default Cost update
I had to purchase a new/reman 105 amp alternator as no one seems to stock a voltage regulator.
Cost update:
Reman alternator= $74.49
Total cost to date= $718.19
I think I'm finally done with this chapter in the book of Corvette upgrades.
Now onto a new project. May be some modern head lights, or a mono leaf front suspension
To TPI install cost breakdown $$$
