Mounting alternator problems with hooker headers installed???
Old Dec 30, 2006 | 10:45 PM
delamorajc's Avatar
delamorajc
Default Mounting alternator problems with hooker headers installed???
I recently installed hooker headers but Jet-hot did not include the "F" mount to be used in securing the alternator. I had them send me one out but can't seem to get the thing to work with the alternator I wonder if I am installing it incorrectly? anyone had a similar problem?
Old Dec 30, 2006 | 10:52 PM
David Ey's Avatar
David Ey
Why would they send an altenator bracket with headers?
Do you have sb or bb?
Can you post a pic?
Old Dec 30, 2006 | 11:40 PM
dmaaero's Avatar
dmaaero
looks like the first bracket they sent goes over the # 1 header tube and is held on by the header bolts then the f braket bolts to that bracket
Old Dec 31, 2006 | 09:40 AM
delamorajc's Avatar
delamorajc
Default SB 68 vette where the alternator was mounted...
Can you post a pic?
I have a 68 small black 327 where the alternator was mounted to the passenger side header
Old Dec 31, 2006 | 09:42 AM
delamorajc's Avatar
delamorajc
Default yeah that makes sense...
yeah when i do that it positions the alt. to high and the hood will not close not to mention the belt would rub on the radiator hose.
Old Dec 31, 2006 | 09:36 PM
SKIPPERS _1's Avatar
SKIPPERS _1
Default alt bracket
WWW.alangrovecomponents.com
they will have anything you need in brackets.
Old Dec 31, 2006 | 10:31 PM
strokervette's Avatar
strokervette
I just got the Hooker super comp sidepipe setup and they included the bracket as well. Mine is a 78 and I don't think the hoods are that much diff in height. The block and heads are from the same era as yours and I don't have any clearance issues. Mine is mounted to the driverside though, couldn't be that much diff. Here is a video of the setup.
http://s85.photobucket.com/albums/k4...Picture001.flv
To Mounting alternator problems with hooker headers installed???
