'70 Side Vent Grill?
Old Dec 31, 2006 | 12:44 AM
Ray Y's Avatar
Ray Y
Default '70 Side Vent Grill?
I'm doing a little homework for a new paint job and ran across a resource that shows in '70 the side grills were only chromed on the horizonal lines. The car was redone by a previous owner about 10 years ago and now sports chrome on both the vertical and horizontal edges. So now I'm wondering if the side vents on the car are maybe from a '71 & up or if my resource is wrong. Can anyone confirm correct scheme for the '70?
Assuming it is correct for the horizontal only chrome, any suggestions on how to remove the chrome on the verticals? I'm guessing just detailed sanding and masking.
Old Dec 31, 2006 | 08:03 AM
wfo76's Avatar
wfo76
The 70/early71 grilles are built different from the mid71/72 grilles, and there is really no way to add chrome to the early grilles, so the car must have the later71/72 or service replacements which were the later style also. If you look at your grilles, you will see the raised horizontal edge that is chromed; the vertical edge should not have this raised part, on the 70 grilles the vertical edge is just flat painted smooth to the end with no place to chrome. If you have the raised chromed edge on both the horizontal and vertical edges, then somebody switched to the later grilles and you will either need to leave it as is or find the correct grilles; no way to remove the chrome from the later grilles and have it look right since the raised ridge will still be there.
Old Dec 31, 2006 | 08:54 AM
dennis's Avatar
dennis
As wfo76 stated, the later grill has a raised edge, or a step up to it. The 70 does not, as you see in the photo. You could however leave the chrome in both directions. I stripped the paint off mine to redo. The entire piece is flash chromed.
You could still tell if it was a 70 grill looking at it closely from the front, or a more obvious difference would be to take the grill off and look at the back. There's a world of difference between the two.
Old Dec 31, 2006 | 09:34 AM
dewcustom's Avatar
dewcustom
Just chrome the whole thing
This is my '70
Old Dec 31, 2006 | 11:49 AM
Ray Y's Avatar
Ray Y
Thanks for the fast input guys.
Dennis-
Your photos didn't attach to your post. Can you please try again or PM them to me.
Thanks again!
Old Dec 31, 2006 | 12:19 PM
dennis's Avatar
dennis
Dennis-
Thanks again!
Old Dec 31, 2006 | 02:41 PM
Ray Y's Avatar
Ray Y
Dennis,
Thanks for the photos.
I've posted a WTB for a set of '70 specific vents on the C3 Parts Forum. Anybody know of an available set for purchase?
Old Dec 31, 2006 | 03:04 PM
dennis's Avatar
dennis
Dennis,
heres a set
http://cgi.ebay.com/ebaymotors/70-71...spagenameZWDVW
Old Dec 31, 2006 | 03:06 PM
dennis's Avatar
dennis
And to see the difference here's a newer piece
Old Dec 31, 2006 | 05:29 PM
Ray Y's Avatar
Ray Y
Dennis,
Thanks again. I've contacted the seller thru EBay.
To '70 Side Vent Grill?
